Windsheild replacement?
Old Mar 24, 2003 | 02:38 PM
Tom 35th anniversary's Avatar
Default Windsheild replacement?
If I have my windshield replaced is there any seals or rubber that must be replaced or is it done only if needed? I have been quoted $225 but that does not include seals or the like and I would like to get a ballpark figure on the job if other stuff is needed.
Old Mar 24, 2003 | 03:17 PM
BaseballDude's Avatar
BaseballDude
Default Re: Windsheild replacement? (Tom 35th anniversary)
I just had the windshield replaced on my '93 and ended up having to replace the pillar weatherstrip afterward. If the inside seal is showing any signs of decay, I would recommend you change that too, as it will look worse once they pull out the old windshield. :(
Old Mar 24, 2003 | 03:42 PM
Steel Blue 91's Avatar
Steel Blue 91
Don't skimp. Replace the windshield seal/gasket. It's cheaper to do it now than to do it over if/when the seal starts to leak. The weatherstrip is your call as it is not effected by windshield replacement.
To Windsheild replacement?
