Nittos or g-force
Old Mar 24, 2003 | 08:23 PM
White LT1's Avatar
White LT1
Default Nittos or g-force
I'm in serious need of some back tires. I do alot of drag racing. I've been set on getting a set of nitto 555R drag radials, becouse their cheap and have great traction. But I'm scared that They may cause rear end trouble. Should I get a set of G-forces instead of the drag radials? How do the g-forces hook up compared to the nittos? Will the nittos cause rearend problems or do I have nothing to worry about?They will be in a 315/35/17 size. Thanks :D :cool:
Old Mar 24, 2003 | 08:40 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Nittos or g-force (White LT1)
I wouldn't get Nitto drag radials, they have no traction compared to BFG's comp T/A drag radials. The Nitto's will last a lot longer on the street, but neither tire is recommended for extended street driving.
The BFG's are very sticky right out of the box where Nitto needs a lot of heat to get them sticky.
Old Mar 24, 2003 | 08:45 PM
White LT1's Avatar
White LT1
Default Re: Nittos or g-force (Mr Mojo)
can they cause rearend problems?
Old Mar 24, 2003 | 08:52 PM
Mr Mojo's Avatar
Mr Mojo
Not really, but if you get caught in the rain, pull over, you will have zero traction.
Some guys have run drag radials on the cars for years with no problems, it only took me about 30 runs to break mine and that was with street tires.
Old Mar 24, 2003 | 09:54 PM
cprgmr's Avatar
cprgmr
I couldn't agree more. I've really only hooked good (no spin) once with the Nittos. My next pair of drag radials will be BFG's! :cheers:
Old Mar 25, 2003 | 12:43 AM
TA's Avatar
TA
I agree with Mojo 100% on the Nittos. I got a set of Nitto drag radials last year and I had fairly good luck with them at the track, but for whatever reason I can't get them to hook at all this year. I've tried everything from lowering the pressure (as low as 16 lbs.) to varrying launch Rpm and these things will not hook. I've been doing some serious burnouts also, but to no avail. I'm seeing some BFG drags in my future :yesnod:
To Nittos or g-force
