driver side door droops
Old Apr 1, 2003 | 08:21 PM
hotrodvette's Avatar
hotrodvette
3rd Gear
Default driver side door droops
Is it difficult to replace the bushings and pins? Any one have any pointers? :confused:
Old Apr 2, 2003 | 12:27 AM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: driver side door droops (hotrodvette)
Is not terribly difficult once you have the correct parts. It is fairly easy to damage the thin edge of your door trying to drive in the upper pin.
You can try to adjust the hang of the door by loosening up the hinge bolts, supporting the door with a jack, and re-tightening the bolts. If the door sags too much, the upper corner of the window glass starts whacking the halo panel and chipping the paint!
You have to unbolt the gill panel and pop the hood for best access to the hinge bolts.
The eventual best fix is to get a new pair of door hinges. Once they star to sag, they've twisted a bit and fatiqued.
Old Apr 2, 2003 | 09:17 AM
BrentDev's Avatar
BrentDev
Default Re: driver side door droops (Matt Black)
Ahhhhh.....another thing on my to-do list. Thanks Matt ----first you got me down about my steering column, now this - you are on top of all the things I need to do.
How about replace the left-hand stalk (brights/cruise/etc). Is that something that would be easy to replace when doing the steering column? (my brights dont work)
Old Apr 2, 2003 | 11:53 AM
redwing76's Avatar
redwing76
Replace the hinge it all wears together.
Old Apr 2, 2003 | 01:32 PM
Wadoka's Avatar
Wadoka
Default Re: driver side door droops (BrentDev)
If you're already disassembling and dropping the steering column to the mid-core, replacing the switch won't make it any harder. You'll have to snake the new switch harness down through the column.
To driver side door droops
