6sp shifter movement?
Old Apr 1, 2003 | 11:35 PM
R23HTC's Avatar
R23HTC
Default 6sp shifter movement?
I know to expect some movement out of the shifter when you get on it in first. My question is how much is to much? It's not like it's hitting the roof :jester . It just seems to be moving quite a bit here recently. Maybe a 1/2" up in first?
Old Apr 2, 2003 | 04:44 AM
CanadaVette's Avatar
CanadaVette
Default Re: 6sp shifter movement? (R94 LT 1)
.5 inch I think that is too much
Old Apr 2, 2003 | 07:59 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
The stock shifter is very sloppy, mine moves around in all gears.(except reverse.
Old Apr 2, 2003 | 08:00 PM
froggy47's Avatar
froggy47
Default Re: 6sp shifter movement? (Mr Mojo)
I never took note, too exciting with the right foot planted, I'll try & notice tonight when I take mine out to play! :party:
Old Apr 2, 2003 | 09:36 PM
sraft's Avatar
sraft
Mine did exactly the same thing when I bought it last summer. It turned out that the C-beam bolts had loosened up, allowing the tranny to rotate upward when torque was applied. Some (if not all) of the load that's usually carried by the C-beam was being carried by the transmission's output shaft bushing. Re-tightening the C-beam bolts eliminated the up/down movement of the stick, but the damage to the bushing and rear seal was costly to repair. :cry
You may have an unrelated problem, but my advice is to not drive it (or drive it very easily) until you figure out what's going on.
Old Apr 3, 2003 | 10:11 PM
JACKSBLK94's Avatar
JACKSBLK94
the stock shifter is poor....i just installed a b&m ripper...it is awesome. there is no comparison it is tight and short. i would recomend it 100% buy one you will wish you bought it sooner!
Old Apr 4, 2003 | 12:13 AM
Rich_01659's Avatar
Rich_01659
Default Re: 6sp shifter movement? (JACKSBLK94)
I had this problem also. and being my first vette i had no idea what was expected. my tranny was loose - all the bolts were about to fall out. now that i have them tight again i can say NO MOVEMENT AT ALL, ROCK SOLID!
get your bolts checked :)
good luck
To 6sp shifter movement?
