Question about weatherstripping......
Old Apr 7, 2003 | 06:18 PM
NEW77GUY's Avatar
NEW77GUY
Default Question about weatherstripping......
There was a topic a while back posted about a great place to buy weatherstripping. Mine is really bad on the driver's side window to the "rear" part of the glass that runs up laterally towards the roof. that's the only part that's really bad. My question is, is that strip one tiny strip, or is it 1 giant strip that runs all the way across the car that runs under the roof panel? I haven't had a chance to take off the roof yet- i don't even know how since i don't have a service manual or owner's manual. Please help guys..... :( :cheers:
Old Apr 7, 2003 | 06:27 PM
85vetteguy's Avatar
85vetteguy
Default Re: Question about weatherstripping...... (NEW77GUY)
That is one piece. Try http://www.corvette-rubber.com , http://www.tld.com or ask for Jeff on the forum. I think it is about $200. Good Luck, Guy
Old Apr 7, 2003 | 06:39 PM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Question about weatherstripping...... (85vetteguy)
:iagree:
It is a one piece weatherstrip. As for removing the roof panel, it is only four bolts. You should have a tool (ratchet and torx) that's used to remove them in the console.
Old Apr 7, 2003 | 07:38 PM
NEW77GUY's Avatar
NEW77GUY
Default Re: Question about weatherstripping...... (Steel Blue 91)
thanks for the replies guys.....as for removing the roof- i see a total of 6 bolts. 2 large torx (i have the wrench) and then 2 smaller ones per side above it i think. Are there any bolts to remove in the front towards the windshield??
Old Apr 7, 2003 | 09:04 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Howdy! :) You should have just 4 screws, or bolts if you will. 2 at the rear of the top that are horizontal, they come all the way out on mine, and if you'll look up at the header at the front of the top, there is one hole on each side you slip your ratchet up into. They stay up in there. Then balance yourself when you pull that puppy off! :D
Old Apr 8, 2003 | 10:19 AM
85vetteguy's Avatar
85vetteguy
Only 4 bolts to remove the roof. 2 in front, 2 in back. Guy
Old Apr 8, 2003 | 10:27 AM
T1Kilr's Avatar
T1Kilr
I got that piece for less than $200 from Jeff, and when you order it, dont forget to get new push-in "tacks" They save you more aggrivation than the dollar or two that they cost.
Old Apr 8, 2003 | 02:20 PM
NEW77GUY's Avatar
NEW77GUY
Default Re: Question about weatherstripping...... (T1Kilr)
i just called on the strip i need guys.....$140.00 Doesn't sound too bad....but i'm having my car go in friday to get the muffler's eliminated. :D :D Priorities, you know? :smash: :cheers:
To Question about weatherstripping......
