Body work on c4???
Old Apr 8, 2003 | 12:32 AM
The13Bats's Avatar
The13Bats
Default Body work on c4???
I have done radical vettes/fiberglass for over 20 years but I have heard in the rumor mill that the c4 is not really fiberglass as in my 81.... :skep:
Some careless person put the screw of the hose clamp that goes on the front of the TPI air cleaner hose on top, when they slammed the hood it made a cracked hole, :cry if it was a c3 I would have it gone in a few hours with bondo, but what do they use on a c4? :confused:
thanks all....
Charlie... :flag
Old Apr 8, 2003 | 08:27 PM
Light84vette's Avatar
Light84vette
Default Re: Body work on c4??? (The13Bats)
Was this before you bought it?? Or did this happen when you owned it and someone else did it? If it was the 2nd one, nothing like a gulf club or bat wont fix, The person that is that did it. :lol:
Not so sure about the hood of the C4 though, And it is fiberglass, when I smashed the front end of my car, yeah it is, you could tell the little fibers underneath it. :yesnod:
GDP's Avatar
GDP
Fiberglass on the C4. Plastic on the C5.
Old Apr 8, 2003 | 08:35 PM
Light84vette
Default Re: Body work on c4??? (GDP)
WTF :confused: C5's plastic? :eek:
Old Apr 8, 2003 | 08:42 PM
Fartleker's Avatar
Fartleker
Default Re: Body work on c4??? (Light84vette)
ive heard here that the c4 body wasnt fiberglass. its SMC, or sheet molded compound. not sure the difference between the two.
Old Apr 8, 2003 | 09:00 PM
The13Bats's Avatar
The13Bats
No I didn't do it, not saying that I might not have made the same mistake but this time I didn't do it, it was there when I got the car...the clamp on the intake on the front of the TPI was on top, I already moved it around....if this hood is fiberglass I can fix it in an afternoon and you will never know it was busted... I just don't wanna go slopping 'glass and bondo on it to have it be some weird GM plastic that the repair will fall off of, I agree it has strands like fiberglass....but see with the replies on here folks aren't 100% sure.... :skep:
Thanks, Charlie. :flag
Old Apr 8, 2003 | 09:08 PM
JSA 007's Avatar
JSA 007
St. Jude Contributor
Default Re: Body work on c4??? (UA89Vette)
:withstupid: It's definitely sheet molded compound, which may contain some fiberglass, but I don't really know what it is either :confused: I'm sure Mr. Mojo knows...
[Modified by JSA 007, 6:08 PM 4/8/2003]
Old Apr 9, 2003 | 06:35 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: Body work on c4??? (JSA 007)
There are SMC specific fillers and fiberglass fibers you can add to fill a hole. Then you need to check compatability of a surface selaer/primer. You use the stuff like usual fiberglass except its not as liqiud its more solid like bondo. You need to grind out a notch around a hole or crack to bond to but it sounds like you know this already. Good luck. :smash:
Old Apr 9, 2003 | 06:39 PM
vader86's Avatar
vader86
Default Re: Body work on c4??? (blk90rdstr)
The hood is fiberglass, special molding but still fiberglass, only a little tougher.
C5s are a plastic composite material.
Old Apr 19, 2003 | 02:40 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
'glass is 'glass.....
Am I wrong????
Am I right?????
tony
:flag
Old Apr 19, 2003 | 02:53 AM
Light84vette
Default Re: Body work on c4??? (oldace84)
At leats its not sheet metal :lol:
The13Bats's Avatar
The13Bats
You're wrong you're right.... :thumbs: :jester
I use to think fiberglass was fiberglass I heard in the rumor mill c4's were not fiberglass the same way c3's are fiberglass, like I said some dork shut the hood with the intake clamp on top and it put a cracked hole in the little valley down the center of the hood about the size of a nickle, if I use bondo like I would on a c3 I could make the hole dissapear in an afternoon..... :skep:
cheers,....
Old Apr 19, 2003 | 03:05 AM
CanadaVette's Avatar
CanadaVette
:mad
Old Apr 19, 2003 | 03:53 AM
Light84vette
Default Re: Body work on c4??? (CanadaVette)
WTF :confused: C5's plastic? :eek: :mad
:confused: Why the flame? If your confused I meant the body, not the whole car :lol:
Old Apr 19, 2003 | 05:46 AM
hngacurv's Avatar
hngacurv
I'd rather have plastic than fiberglass anyday. That was one of the things I loved about my Fiero.
Old Apr 19, 2003 | 09:44 PM
Light84vette
Default Re: Body work on c4??? (hngacurv)
But the doors have to be of some sort of metal right? Either aluminum or Steel? Because on my TransAm, the front fender and the rest feel like plastic but the doors pretty solid.
Old Apr 19, 2003 | 11:06 PM
DanielW's Avatar
DanielW
St. Jude Donor '04-'05-'06-'07-'08
yeah but the trans am is not a vette. The bumpers in most cars today are made of plastic to make replacement cheaper and easier.
To Body work on c4???
Old Apr 19, 2003 | 11:18 PM
Netnarc2's Avatar
Netnarc2
Default Re: Body work on c4??? (DanielW)
The 13 Bats, are you sure that you've got the correct clamps on your intake? There are two of them. Both of my clamps have the screw assembly on top and they don't come anywhere near hitting the inside of the hood. Maybe the previous owner changed the clamps and put something on there that is too big.
Old Apr 20, 2003 | 12:25 AM
The13Bats's Avatar
The13Bats
Default Re: Body work on c4??? (Netnarc2)
I'm not sure it's the right clamps, that's just what lines up with the hole/crack, maybe there was different clamps on it at one time that did the damage, I turned the clamps over to the side to be safe, the air intake is not 100% stock so that may be where the problem came in but I really don't know for sure how it happened , it was before I bought the car....
Cheers, :thumbs: :flag
Old Apr 20, 2003 | 09:07 AM
edsalinas's Avatar
edsalinas
The C4 body panels are SMC, sheet moulded compound. They consist of plastics, resins and fiberglass particles. They're fabricated in high pressure molds. SMC is an epoxy base product, so the best structural repairs are made with epoxy base bondo's. One of the strongest I've found is J.B. Weld. You can also use epoxy resin with fiberglass matte. Evercoat makes a resin called "SMC Resin", but a chemist friend at work looked into the materials and found it to be a polyester product, so I would stay away from it. Polyester can soften epoxy. Non structural finish work can be done with polyester products.
Eklers sells a couple of self help videos for this type of info.
Hope that helps alittle . . . . . . . .
:cheers:
