84 Vacuum problem
Old Apr 9, 2003 | 06:52 PM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Default 84 Vacuum problem
Whenever the heat or air conditionining is on in my '84 vette, the air flow comes out of all holes. The heat works, and the Air works, but I can't switch between the floor, vent or defroster--comes out in all 3 places.
Are there common problems when it comes to this? I've already replaced the vacuum thingy that the hoses contraption behind the dash slide switches plugs into--that black plastic thing that turns by vacuum is what I replaced. The little prong/tip is in the track and everything, but the air flow still comes out of all holes. When I move the slide directional switch, the vacuum actually turns the thing. I replaced the black thing that the hoses plug into just in case--the old one worked (the wheel turned when I moved the slide switch) just like the new one works.
What's up with that?
*My cruise works whenever it wants to and I have a hesitation/cough sometimes when I step on the gas as I'm going a steady speed around town. To me this indicates a vacuum problem. Yea--I'm a brainiac.
Help! :banghead:
Old Apr 9, 2003 | 06:59 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: 84 Vacuum problem (84 Cross Fire)
Sorry I havent had that problem yet! :smash:
Old Apr 9, 2003 | 10:42 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
If it's not the thing, it could be the thing. Or maybe even the thing. I've got the same problem on my '86, and it's a broken vacuum line running from behind the distributor to the vacuum check valve near the firewall. It's hard to get to and I'm lazy. Bad combination.
Old Apr 10, 2003 | 12:10 AM
84number2083's Avatar
84number2083
Haven't had that rpoblem yet...did I say YET? I do get a hesitation when I switch from vents to defrost, etc as if the vacuum is trying hard to make the switch, but it does work after about 5 seconds.
Old Apr 10, 2003 | 07:38 AM
C-4 Cross Fire
Default Re: 84 Vacuum problem (flyersfan1088)
How do you know--how did you find out that that was where the problem was? :confused:
To 84 Vacuum problem
