C4 Speedometer
Old Apr 10, 2003 | 08:31 AM
efweber's Avatar
efweber
Default C4 Speedometer
The graphic digital display in my 84 C4 goes to 85 MPH. If I go faster than that, will the number display go higher, or does it also cap at 85? Also, did the speedometer display go higher on Corvettes after 1984, i.e. do later models have speedometers that go to 100+?
Old Apr 10, 2003 | 08:47 AM
Blue88's Avatar
Blue88
Default Re: C4 Speedometer (efweber)
The digital numbers will go to 100+.
[Modified by Blue88, 7:49 AM 4/10/2003]
Old Apr 10, 2003 | 10:36 AM
Patrick96LT4's Avatar
Patrick96LT4
Cruise-In II Veteran
Default Re: C4 Speedometer (Blue88)
Mine goes to 160. :lol:
Old Apr 10, 2003 | 11:13 AM
bluestreak63's Avatar
bluestreak63
I'm not that familiar with the cluster for the 84, but I'm sure it has a button to go from MPH to KMH. I don't know the exact conversion, but if you're running around 65-70mph, hit the button and it should register around 115-120kph.
Old Apr 10, 2003 | 11:17 AM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Default Re: C4 Speedometer (bluestreak63)
which would imply that it can go over 99
Old Apr 10, 2003 | 12:14 PM
flannel_man's Avatar
flannel_man
Cruise-In VI Veteran
:withstupid: the 84' has the slide button to switch between english and metric readings. When you go over 85 the bars are all the way up, and the digital numbers keep climbing, even over 100 :D Give it a try sometime. And when you get to 140 mph switch it over to kph to see BIG numbers :jester
Old Apr 10, 2003 | 01:41 PM
JSA 007's Avatar
JSA 007
St. Jude Contributor
Default Re: C4 Speedometer (flannel_man)
:iagree: Since it's digital, the numbers up to 85 on the side can change also (not like a analog guage with a needle pointed at fixed numbers). I also think you should give it a try sometime. I mean the only way to know for sure is to go and do it yourself :lol:
To C4 Speedometer
