Climate Control has NO POWER
Old Apr 16, 2003 | 03:45 PM
87greenwoodvette's Avatar
87greenwoodvette
Default Climate Control has NO POWER
My Climate control has no power,,, does anybody have any suggestions on what to check besides the fuses to fix this problem.
Thanks for all your HELP, in advance :steering: :grouphug:
Old Apr 16, 2003 | 04:38 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Default Re: Climate Control has NO POWER (87greenwoodvette)
Try the CLCK/CTSY fuse. I know you didn't want a fuse listing, but its not obvious.
If that doesn't work thry taking the module out of the dash, clean the contacts and put it back in.
Its probably a fuse though.
Old Apr 17, 2003 | 09:27 AM
87greenwoodvette
Default Re: Climate Control has NO POWER (jaa1988)
i have already tried 2 different contol boxes,, and neither one works. I also checked all the fuses. The only other repairs i made on car was to pull the computer chip assembly out from under the passengers side dash.
Old Apr 17, 2003 | 12:29 PM
scorpion's Avatar
scorpion
dumb question:
do you have vacum to the unit?
Old Apr 18, 2003 | 11:22 AM
87greenwoodvette
Default Re: Climate Control has NO POWER (scorpion)
There is no SUCTION to the Controler,, it has a PLUG-IN the back with about 20 wires.
To Climate Control has NO POWER
