Bad alternator?????????
Old Apr 24, 2003 | 04:40 AM
VETHEAD JR's Avatar
VETHEAD JR
Default Bad alternator?????????
I was driving home and stopped off to see a friend, I stopped the car and kept the radio on. I walked away for about 30min. When I came back the radio was off and the battery was dead. So I had to get a jump. Now I am getting a flashing light on the console that says sys. I was wondering if any of you could know what’s up with my car. My Batt is sitting at 14.3 volts after driving home after 10 miles and the battery is dead again. So I am thinking alternator might be bad. Any help you can give would be appreciated. thanks.
:seeya :flag :seeya
Old Apr 24, 2003 | 02:19 PM
Mikez40's Avatar
Mikez40
Default Re: Bad alternator????????? (VETHEAD JR)
Sounds like your battery is bad. I would take it out and have it checked at an autoparts store, before I replaced the Alternator. If your alternator was bad, you will not see 14 volts on your gage, and more than likley your car would stall. If your battery is more then a couple years old and it drained down, that could cause it to short or open condition.
Old Apr 24, 2003 | 03:20 PM
stinger95's Avatar
stinger95
Cruise-In IV Veteran
Default Re: Bad alternator????????? (Mikez40)
:iagree:
Old Apr 24, 2003 | 04:28 PM
VETHEAD JR's Avatar
VETHEAD JR
i took the car in and they said that the battery was good. They found nothing wrong with the car. You know i hate it when you go in and the people look at you like your dumb. Umm sir there is nothing wrong with your car it must just be you. oh well. Thanks Guys.
:seeya :flag :seeya
Old Apr 24, 2003 | 04:33 PM
stinger95's Avatar
stinger95
Is it the battery itself that's reading 14.3? Or is it the meter in the car?
Old Apr 25, 2003 | 03:36 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Get a new battery...it must be time......has all the symptoms of a bad battery....
go for a good one....ultima.....thats what I will when I need another battery....
tony
:flag :iagree:
Old Apr 25, 2003 | 03:45 AM
CanadaVette's Avatar
CanadaVette
Default Re: Bad alternator????????? (oldace84)
tony
:flag :iagree:
:withstupid:
Old Apr 25, 2003 | 09:48 AM
Phil-tha-Rush's Avatar
Phil-tha-Rush
Default Re: Bad alternator????????? (CanadaVette)
did they check the "cranking amps" on the battery?
if it an old battery, it is possible that the volage reads ok, but that it wont hold its cranking amps.
I know, becuase I just replaced one like that about 6 months ago :seeya
Old Apr 26, 2003 | 11:54 AM
redwing76's Avatar
redwing76
Get a volt meter and check the battery. Min of 13 volts with engine off.
Check the battery with the engine running, should show 13-14.5 volts.
The battery should have a charge over 12.5 volts all the time. 12.5 will start the car. 11.5 wont.
Average charge on a low battery should be 13-14 volts.
If the battery has a cell that has shorted out there will be no charge when the car is running.
Again check the battery at rest and with the car running.
To Bad alternator?????????
