Wiper Problems on 84
Old Apr 25, 2003 | 04:32 PM
84 Cherry's Avatar
84 Cherry
Default Wiper Problems on 84
I have plenty of windshield fluid but it will not come out. How do I test the pump to verify that the pump still works and that one of the lines is not cloogged?
Old Apr 25, 2003 | 06:01 PM
The Gooch's Avatar
The Gooch
St. Jude Donor '06-'07-'08-'09-'10
Default Re: Wiper Problems on 84 (84 Cherry)
Remove the hoses that feed into the sprayers going to the windshield. Then turn it on. If they spray, then the windshield sprayers are clogged. Use a safety pin to clean them out. That is usually the problem.
Also check the filter in the windshield resivour. It could be clogged.
Old Apr 25, 2003 | 07:19 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Default Re: Wiper Problems on 84 (The Gooch)
:iagree:
And after you get them working never use plain water since it tends to build up corrosion and block lines.
To Wiper Problems on 84
