HELP!! OIL CHANGE LIGHT
Old Apr 29, 2003 | 04:43 PM
daz_96CE_greenwood's Avatar
daz_96CE_greenwood
Default HELP!! OIL CHANGE LIGHT
ANYONE KNOW HOW DO I RESET THIS LIGHT, JUST HAD OIL CHANGED AND IT CAME ON ABOUT 200 MILES LATER???????????
Old Apr 29, 2003 | 05:12 PM
Scoob's Avatar
Scoob
Default Re: HELP!! OIL CHANGE LIGHT (daz_96CE_greenwood)
It's in the manual. It's an easy procedure. I don't have mine with me right now. I'll post it tonight if nobody gets it to you by then.
Old Apr 29, 2003 | 05:14 PM
Steel Blue 91's Avatar
Steel Blue 91
Don't quote me on this since I have a 91, but it should work:
1. Turn engine off.
2. Turn ignition switch to the on position
3. Push and release the "eng/met button"
4. Within 5 seconds, push and release the "eng/met button" again
5. Within 5 seconds, push and hold "gauges" button
6. Change oil light should blink for about 5 to 10 seconds then go out.
That should do it.
Old Apr 29, 2003 | 05:35 PM
daz_96CE_greenwood
kewl, don't guess you know how to disable the LTPWS light do you????
Old Apr 29, 2003 | 05:41 PM
daz_96CE_greenwood
Default Re: HELP!! OIL CHANGE LIGHT (Steel Blue 91)
IT WORKED!!!!!!!
:party:
thanks guys!
To HELP!! OIL CHANGE LIGHT
