Gear Ratio
Old May 7, 2003 | 05:20 PM
Baaad96's Avatar
Baaad96
Default Gear Ratio
What is the gear ratio for a 96 auto vert lt-1 ? :chevy :chevy :chevy :chevy :chevy
Old May 7, 2003 | 05:35 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Gear Ratio (Baaad96)
2.59 stock, 3.07 if you have the performance axle which is RPO G92
Old May 8, 2003 | 01:17 AM
Mikez40's Avatar
Mikez40
Default Re: Gear Ratio (Mr Mojo)
On a vert you get the 2.73 if you have the performance axle, the coupe gets the 3:07
Old May 8, 2003 | 11:21 AM
SOVAIN1's Avatar
SOVAIN1
Default Re: Gear Ratio (Mikez40)
whats the difference between the 2.73 and 3.07 I am very curious!
Old May 8, 2003 | 01:49 PM
Baaad96's Avatar
Baaad96
Default Re: Gear Ratio (SOVAIN1)
Thanks for the info,now to check the RPO,I wonder how many 96 vettes have the performance axle, would not think alot , but could be wrong. Oh by the way Mikez you have one Bad looking vette!!!! Are you going to bring z to the forum get together over the memorial day weekend bash? :chevy
Old May 8, 2003 | 02:28 PM
Scoob's Avatar
Scoob
9,801
45.5% of all '96 have RPO G92
Old May 8, 2003 | 02:55 PM
Baaad96's Avatar
Baaad96
Default Re: Gear Ratio (Scoob)
I would of never thought thought that 45.5% had the performance option, i have almost a 50/50 chance I have the RPO G92!
Thanks alot Scoob :thumbs: :thumbs:
Old May 8, 2003 | 03:23 PM
Mr Mojo's Avatar
Mr Mojo
Are you sure about that? I've never heard such a thing.
I know some early C4's had 2.73's and the C5's have 2.73's, but I never heard of a LT1 C4 with 2.73.
Old May 8, 2003 | 05:24 PM
Mikez40's Avatar
Mikez40
I am positive, I had a 1993 Vert with the G92 option and it had the 2.73 gears. I did some checking at the time, and found out that they did not put the 3.07 gear in the vert. However I am sure if someone special ordered the car they could of got 3.07 gears. If the performance axle was order on the vert you automatically got the 2.73 gear, and on the coupe you automatically got the 3.07 unless otherwise specified.
Look under your arm rest and check the option codes:
GU2 2.73 Rear Axle Ratio
G44 3.07 Rear Axle Ratio
By the way, the G92 option only cost $50.00
Mike
[Modified by Mikez40, 4:31 PM 5/8/2003]
Old May 8, 2003 | 05:28 PM
JSA 007's Avatar
JSA 007
St. Jude Contributor
:iagree: Although I can't really speak for verts. Anyway the code for the 3.07 rear gear is G44. So you could specify G92, the performance axle, and then a different code for the actual gear ratio.
:cheers:
Old May 8, 2003 | 06:05 PM
Mr Mojo's Avatar
Mr Mojo
Man, you learn something new everyday.
Old May 9, 2003 | 01:55 AM
SUPERNINJAB0Y's Avatar
SUPERNINJAB0Y
what about an 87 vert? 2.73's or possibly 2.59's?? Im unsure, its a friends and i didnt' bother to look for the code. Or is there only one option for those L98 cars????? :skep:
Old May 9, 2003 | 10:08 AM
Mikez40's Avatar
Mikez40
Default Re: Gear Ratio (SUPERNINJAB0Y)
On an '87 you got 2.73 unless you have (RPO G92: 3.07)
To Gear Ratio
