digital dash question--what is this?
Old May 8, 2003 | 11:05 PM
radwebster's Avatar
radwebster
Default digital dash question--what is this?
i have noticed that there is a little tiny square to the top-left of my speedo on my '84 digital dash...it looks like there is a light in there, but it has never come on, and i have no idea what it does..just wanted to see if anyone knows about it..thanks! :)
Old May 8, 2003 | 11:07 PM
Ramanstud's Avatar
Ramanstud
Default Re: digital dash question--what is this? (radwebster)
I can't remember either... flip through your owner's manual- maybe it lists the display fxns in there??
Old May 8, 2003 | 11:12 PM
Netnarc2's Avatar
Netnarc2
Default Re: digital dash question--what is this? (Ramanstud)
The little square window on the left side of the dash, about 1/4"X1/4" is your sensor that tells the dashboard lights how dark it is outside, so that the lights will adjust and be easier to see. You can test it by putting your finger over the hole or moving your finger near the hole to see if your dashboard lights get brighter or darker. I just found out a few weeks ago, myself. I noticed that each time I pulled into and out of our well lit garage at night, the dashboard lights would dim.
[Modified by Netnarc2, 4:14 AM 5/9/2003]
Old May 8, 2003 | 11:19 PM
Grouchy67's Avatar
Grouchy67
Supposed to be a light sensor - change your readout brightness for day or night. Have one in mine that does not change the light intensity but the dash works so I call it good enough. :yesnod: :steering:
Old May 8, 2003 | 11:41 PM
radwebster's Avatar
radwebster
Default Re: digital dash question--what is this? (Grouchy67)
nice, i have noticed that it gets brighter at night. thanks :thumbs:
Old May 8, 2003 | 11:43 PM
Lord Odin's Avatar
Lord Odin
If that's for the lights, then what's the little sensor near the front-middle of the windshield for? :confused:
Old May 8, 2003 | 11:47 PM
84number2083's Avatar
84number2083
:skep: Hmmmm...when I put my headlights on my dash goes dimmer, which makes sense since it should be brighter during daylight so you can see it and less blinding at night. Turning the headlight **** also adjusts the brightness. Never knew there was a sensor at all!
Old May 8, 2003 | 11:48 PM
Lord Odin's Avatar
Lord Odin
Default Re: digital dash question--what is this? (84number2083)
:iagree: I always adjusted the level manually. Never noticed the brightness change at all automatically.
Old May 8, 2003 | 11:53 PM
radwebster's Avatar
radwebster
Default Re: digital dash question--what is this? (Lord Odin)
i have seen that you can adjust the brightness of the dash, but only when you have your lights on. i tried in the day and it won't change manually.
Old May 9, 2003 | 07:59 AM
Aaron71771's Avatar
Aaron71771
One of three temperature sensors that the electric climate control uses.
Old May 9, 2003 | 09:36 AM
CMYC4GO's Avatar
CMYC4GO
Default Re: digital dash question--what is this? (Aaron71771)
That little square is your ambient light sensor, and it works very well, or at least mine does, and it should even work at night with your lights on. A good way to test how well it is working is as follows:
1. Daytime---Dash should be well lit.
2. Nightime (Full Dark)---With lights off, your cluster lights should be barely visible.
3. Nightime with lights on----Dash lights at normal brightness, pull into a very brightly lit gas station or something like that, and your dash lights should get even brighter still. :seeya
To digital dash question--what is this?
