Also getting a vibration
Old May 12, 2003 | 04:11 PM
rainsux89's Avatar
rainsux89
Default Re: Also getting a vibration (Lord Odin)
Vibration here too on my 89 Convertible. Very noticeable from 65-80 then it smooths out a little but it's still there. Mine is the opposite of Lord Odin's, it gets less shakey the longer I drive it.
Lord Odin, does the steering wheel shake or do you feel vibrations in the seat? If it's the wheel it's a front end problem, in your seat, it's a rear problem, or so I've been told. :cheers:
Old May 12, 2003 | 06:57 PM
Lord Odin's Avatar
Lord Odin
Default Re: Also getting a vibration (rainsux89)
Nah, its definitely not wheel related. I thought the same thing at first. But usually if its in the rear, you still get a tiny bit in the sterring wheel as well; just not as much. Its definitely a sort of vibration cause I can feel it really well in reverse going only a few mph.
Old May 12, 2003 | 08:20 PM
CorvetteCoupe93's Avatar
CorvetteCoupe93
Check the rear wheel bearing assemblies I had this problem with my car too :yesnod: I replaced the U Joints at the same time :yesnod:
[Modified by CorvetteCoupe93, 7:21 PM 5/12/2003]
Old May 12, 2003 | 08:21 PM
Lord Odin's Avatar
Lord Odin
Default Re: Also getting a vibration (CorvetteCoupe93)
I just said it wasn't wheel related. I can even get it in neutral stopped. :banghead:
Old May 13, 2003 | 01:01 AM
GusBustamanteJr's Avatar
GusBustamanteJr
Get up to 90 and put it in nuetral and coast, see if problem persists.
Check the driveshaft, u-joints, and rear c-beam (comes loose alot). Motor mounts dont rust in place! They need replacing after a while, check them too.
Old May 13, 2003 | 03:01 AM
Lord Odin's Avatar
Lord Odin
Default Re: Also getting a vibration (GusBustamanteJr)
Hmm. I didn't shift to neutral but the other day I did go 90+ and then coasted down about 20 mph. I'll try shifting tomorrow.
Old May 13, 2003 | 06:26 PM
CorvetteCoupe93
[Modified by CorvetteCoupe93, 7:21 PM 5/12/2003]I just said it wasn't wheel related. I can even get it in neutral stopped. :banghead:
:rolleyes: Have fun
