custom fiberglass
Old May 16, 2003 | 01:34 PM
luck38's Avatar
luck38
Default custom fiberglass
has anyone done custome fiberglassing in the interior of their car? I'm looking to possibly create a custom dash, center counsel, and the interior portion of the doors. I'm looking for information on how to create colds, fiberglass techniques etc.
Old May 16, 2003 | 02:09 PM
Bodhi's Avatar
Bodhi
Default Re: custom fiberglass (luck38)
Check over in Audio/Electronics section of this forum.....several of those guys do extensive fiberglass work when making speaker enclosers/custom mounts for the rear of their cars.
Old May 17, 2003 | 04:28 AM
GDP's Avatar
GDP
I do fiberglass work, making custom car audio stuff.
Have you ever worked with fiberglass before?
Old May 17, 2003 | 07:47 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Check with Arisa! He's done some NICE custom glass work on the interior of his '96! :thumbs:
Old May 17, 2003 | 08:25 AM
luck38's Avatar
luck38
no i never worked with it before, but i am willing to research and learn.
Old May 18, 2003 | 03:15 PM
GDP's Avatar
GDP
A bit of advice, don't attempt a dash for your first thing.
My friend and I build custom car audio stuff with glass, and we're slowly learning tricks here and there to make it better. I'll help you with whatever you need help with, but fiberglass is difficult to work with, I won't lie to you.
It takes lots and lots of patience. Feel free to IM or email me if you have questions. :thumbs:
[Modified by GDP, 2:16 PM 5/18/2003]
Old May 19, 2003 | 10:50 AM
smittyvette57's Avatar
smittyvette57
I just made a panel to replace my acrylic top using fiberglass. I would suggest using the cloth as opposed to the mat. It came out fairly well but needs a little work to be nice. Another tip if you are trying this for the first dont "paint" the resin on, dab it into the cloth. This will prevent unwanted stretching of the cloth. However sometimes it needs to streched to lay flat on tight corners. You also need acetone, mixing and measuring containers, and some cheap paint brushes. Also if you have a mold you dont want to ruin using tin foil makes a nice barrier.
To custom fiberglass
