Passenger window switch
Old May 18, 2003 | 08:33 PM
CanadaVette's Avatar
CanadaVette
Default Passenger window switch
Is there a safety on the apssenger side window that does not allow the passenger to control the window?
I can make the window go up and down from the driver's side but I can't make it go up and down from the passenger's side.
PS I am new to this car. 2 weeks old for me.
94 vette :confused: :confused: :confused:
Old May 18, 2003 | 08:48 PM
KY Vette's Avatar
KY Vette
Default Re: Passenger window switch (CanadaVette)
Not that I'm aware of. Sounds like the switch on the passenger side may be bad. :(
Old May 18, 2003 | 08:50 PM
offershore's Avatar
offershore
The sw. sucks. about $7.00 us. for a new one. 15 min to change. (get 2)
Old May 18, 2003 | 08:54 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Nope. No safety on a 91. The switch may be faulty or just unplugged. You can remove the door panel to check for continuity or for a bad switch. On the 91 door the switch easily pops out without removing the door panel.
If you must replace the switch, check with your local GM parts dept. If it is too expensive, there are several places to get used switches.
All in all this is not a difficult or expensive project if it is just the switch. Good luck! :thumbs:
[Modified by brdd, 7:55 PM 5/18/2003]
Old May 18, 2003 | 09:55 PM
CanadaVette
Old May 19, 2003 | 11:43 AM
redwing76's Avatar
redwing76
Check for a fuse. Get a test light and check the power at the switch.
Old May 19, 2003 | 11:46 AM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Passenger window switch (KY Vette)
:iagree:
To Passenger window switch
