Water
Old May 18, 2003 | 11:25 PM
CanadaVette's Avatar
CanadaVette
Default Water
I have water in my hood latch over the battery. Where the pin of the hood gets latched on. The small bucket over the battery is full of water but the one on the passenger’s side is empty.
Is there a drain plug that may be clogged?
I am afraid of drilling a hole in it because the battery and other electronics are directly beneath it.
Thanks Mike :confused:
Old May 18, 2003 | 11:52 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
Default Re: Water (CanadaVette)
Most of us have water collect in that area as well. Good news is, most aftermarket supply houses sell kits that will remedy that situation. Bad news is, you'll have to drill a hole to attach the drain tube and then route it around and under the battery or wherever it takes.
Old May 19, 2003 | 12:11 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
In 1995 they put drain tubes in there, you can buy a kit like George said.
Old May 19, 2003 | 12:33 AM
Teh Nam's Avatar
Teh Nam
Default Re: Water (Mr Mojo)
I don't have one!
Jay
Old May 19, 2003 | 02:27 AM
linkschamp's Avatar
linkschamp
On my son's '92 Coupe, there is indeed a rubber drain directly above/behind the battery - there is none on the passenger's side. We have lots of woods behind our house and the 8" rubber tube that hangs down gets filled with pine needles. Its a simple clean-out, the end is split and opens up to remove the debris. Check and see if you have this same tube and if its filled with crap...
To Water
