A bad spark plug story ! ! !
Old May 19, 2003 | 01:55 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default A bad spark plug story ! ! !
A friends opti died in his '92 so he relpaced the plugs, wires etc. He bought the top of the line "Bosch" platinum whatever's and when he was all done, the car ran like a pos.
After much aggravation he had it towed to the dealer. They ran a diagnostic on it and discovered that the new Bosch plugs were defective, shorting and not firing consistently.
Makes you wonder huh?
:mad
Old May 19, 2003 | 03:15 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: A bad spark plug story ! ! ! (edsalinas)
I bet heads will roll in QA for that SNAFU. :cuss
Old May 19, 2003 | 03:41 PM
Bat Man's Avatar
Bat Man
Default Re: A bad spark plug story ! ! ! (65Z01)
I wouldn't buy platinum plugs. From what I hear they are pretty bad.
Had them in my old vette, and my mechanic shat a brick when he saw them, and said they weren't supposed to be in vettes. So I don't know.
Old May 19, 2003 | 04:22 PM
edsalinas's Avatar
edsalinas
Default Re: A bad spark plug story ! ! ! (Marty McFly)
:crazy: :crazy: :crazy:
It'd be nice to get some technical input on this one huh?
Old May 19, 2003 | 05:45 PM
Mikez40's Avatar
Mikez40
AC Delco platinum plugs have been the factory installed plug since 1993. I don't know what your mechanic is smokin, but I have never seen any problems with the factory recommend plugs. If you stick to what is known (and tested by GM) to work, you will have less problems. :cheers:
Old May 19, 2003 | 07:31 PM
Lone Ranger's Avatar
Lone Ranger
Also, the way the spark plug hole is angled in the L98/LT1/LT4 heads, a spark plug using the conventional L-shaped ground strap does a good job of exposing the spark kernel to the air/fuel charge. The open electrode types like the +4's and Bosch plat2's are not the optimum design for our cars' heads.
Old May 19, 2003 | 07:49 PM
CanadaVette's Avatar
CanadaVette
Thanks for the info
Old May 19, 2003 | 11:22 PM
Lone Ranger
Default Re: A bad spark plug story ! ! ! (lani's 93)
Lani did you ever find a source to buy the black high temp plastic spiral cut spark plug wire guards from?
I'd like to know if you did, in case I need to source some sometime...:D
Old May 20, 2003 | 12:17 AM
GDP's Avatar
GDP
Bosch plugs suck. I've heard it before, and this just further builds my opinion against them. My 'vette mechanic swears that they're nothing but poopie. I would tend to believe him, he sees 'vettes day in and day out... that's his profession.
[Modified by GDP, 11:24 PM 5/19/2003]
Old May 20, 2003 | 01:21 AM
jefft84's Avatar
jefft84
Default Re: A bad spark plug story ! ! ! (GDP)
Did anyone think that the box of plugs had been dropped before you got them? maybe even the whole case? Its the real world people this crap happens. One of my techs wont use Bosch in anything he claims they are junk swears by AC/Delco, so the other day when I did a tune up on a car and it had a misfire he says something about I must have used Bosch , I just told him to scope it for me and find out what cylinder was missing and I would get another plug ordered. Actually found 2 bad plugs and they were Delco not Bosch like he thought I had used It happens to every brand. As far as platinums in a Vet or not, its not about the car its about the ignition design some cars will act adversly to the lower resistance of a platinum plug verses a copper core that it was originally designed for, and vice versa.
Old May 20, 2003 | 09:03 AM
Lone Ranger
Default Re: A bad spark plug story ! ! ! (jefft84)
Bada Bing. Same thing a GM master tech told me: stock LT1 ignition system designed for platinum plugs, said use only platinum or can substitute the new iridium designs since iridium plugs have lower resistance not higher. Said that although copper is better conductor, its the diameter of the electrode *end* that establishes resistance-- smaller diameter at end of electrode means easier to push spark through i.e. lower resistance.
I've tried new sets of the stock AC 41-906, NGK TR-55 (copper), and NGK TR-55ix (iridium). The TR-55ix's feel better than the AC 41-906's which felt better than the NGK TR55's. But what do I know?... :D
[Modified by Lone Ranger, 8:05 AM 5/20/2003]
Old May 20, 2003 | 10:26 AM
redwing76's Avatar
redwing76
I use Auotlite plugs only.
Carbon plug wires are crap. Why carbon plug wires? Radio.
Bosch plugs, NGK plugs, not in an American car. AC plugs are "cold" plugs and tend to wear out quicker than Autolites. Autolites are a "hot" plug and burn better and longer than a "cold" plug. Hot plug, cold plug, anyone know the difference?
Platnium plugs, iridium, sodium plugs??????????BS.
Plug life can run to 100,000 miles. What killed the plugs in early cars was the lead in gasoline. Once the lead was gone the plugs last a lot longer. No more burn out. But what does happen is the the gap increases with mileage.
The longer you run a plug the wider the gap becomes. Eventually the spark shorts to the head. Thus creating a high speed miss.
American engines need American plugs. They're engnieered for American cars. I hate changing plugs thats why I use Autolite plugs.
Bosch, NGK, good in Nipper cars only.
YMMV. Of course I could be wrong. It wouldn't be the first time.
Buy American. :flag
Old May 20, 2003 | 06:29 PM
edsalinas's Avatar
edsalinas
So which AC Delco part no. 41-913 or 41-904 ? ? ?
Old May 20, 2003 | 06:43 PM
edsalinas's Avatar
edsalinas
:thumbs:
Old May 20, 2003 | 06:47 PM
Lone Ranger
This as always an interesting discussion. I'm curious about the comment that they feel better. What do you mean by feel better? Does that mean in your hands they feel better, or does the engine's operation feel better via the vibrations it creates when its running due to one spark plug performing differently than another?
Better throttle response, better low-end pull.
I'm concerned about the use of titles, would you trust the advise of a GM Master Tech who installs plugs in an aluminum head without using anti-seize? Would you trust their advise if the work they perform is less than adequate? What about mis-routing cables when they reassemble after performing maintenance and purposely spliting the wires leaving a harness and put half of the wires on one side of a waterpump hose and some on the other? What about ensuring the plug wires are in all the wire trees, if they ignore the trees and just leave the wires hanging, does that make the GM Master Tech the best source of advise? I'll let you all be the judge, but be assured that list can go on and on from what I've seen come out of Chevy GM Master Techs.
You apparently drew a tech that was less than competent or at least was not concerned with doing a good job. That does not mean they are all that way. There is no doubt in my mind that someone who has earned official recognition/documentation of their auto mechanic skills probably knows more about automotive mechanical issues than I do, so I have a tendency to at least listen to their advice and thoughtfully consider it.
I swear I read an article here recently about what Iridium was suppose to provide over platinum but I cannot locate it at the moment. I will keep looking. But to the best my memory serves me, I don't believe it offered much over the platinum metal. Of course other than being more expensive.
Unit for unit Iridium has a lower resistance than platinum but slightly higher than copper, but due to its hardness it can be made to a much thinner diameter than a copper electrode and as such can render a fringe benefit of equal or lower resistance than a larger diameter copper electrode. This is how I understand it.
So are you saying that the diameter of the electrode in NGK cooper plugs is smaller than those on the same specification platinum plugs?
No.
If I understand your post correctly your saying that the objective is to have a lower resistance? So wouldn't that be a better situation?
Yes.
Why is there such a varying selection of opinions on this subject? I'm seriously curious.
'cause opinions are like... well you know... every body has one.
Some swear by the NGKs, others warning of the hazards of the AC platinum, seems like the general consensus is to definitely avoid the Bosch plugs.
Agreed, mostly. The hazards of AC platinum seem to be the possibility of the platinum pucks departing the spark plug and going hither to parts unknown within the motor. Maybe they will, maybe they won't but once I heard the stories it bothered me until I removed them and verified they all still had their pucks. I then put in the iridium spark plugs.
It sure would be nice to have valid and consistent information about this subject.
Agreed.
Especially where the line can be drawn to stipulate in a LT-1 for normal use the most optimum plug would be ___? For conditions like racing, the optimum would be ____? Now it may not be that clear cut, but we should be able to narrow it down to if you use this type your going to get these results.
Too many subjective opinions out there with no hard data to back up the claims (from guys like me ;) ) it'll never happen...
If we had access to the engineering data on this from the Corvette designers we would know why they choose what the did and for what reasons, and the reasons why not to use others based on their test results. Otherwise in many cases we're pretty much guessing.
Yep.
My objective is to obtain the best data available to make the best decisions so that I can get the desired results from the best part. Because from my dealer experiences taking a Corvette to Chevy for one problem and getting back with another and when its left with them for an extended period of time the GM Master Tech scratches his head and states I have no idea why its missing leaves much to be desired.
Time to find another service shop and/or mechanic, preferably a Corvette intensive shop.
What do you know, well I can say this you certainly know more than some since you've tried three of the plugs being discussed and have some first hand experience to share, that is something.
Lani
I call it adding my $0.02 worth :D
:cheers:
Old May 20, 2003 | 06:54 PM
edsalinas's Avatar
edsalinas
Default Re: A bad spark plug story ! ! ! (Lone Ranger)
Wow, how 'bout those Mets?
:lol: :lol:
:thumbs:
Old May 20, 2003 | 07:35 PM
Lone Ranger
Yikes... my long post generated a huge long reply. Thanks I appreciate the comments and clarifications. So you switched to the TR-55ix's and those are the one's that your most happy with overall? I haven't bought the plugs yet, the wires are on their way should be here tomorrow, that's why I'm so interested beside the obvious.
I like the TR55ix's best so far. For a more reliable version (no magic flying pucks) of the stock plugs I have heard the Autolite double platinums are good.
Or leave your tools in the hood latch so that the hood is not fully closed, and the owner drives away with a shaky no closed hood, notices it gets out finds the tool and returns it to them.
Finders keepers! 'Specially if they gave me my car back all smudged up and funky.
In most cases I think all the .02 opinions are more valuable.
That's why I like it here. While it may be time consuming, you can glean quite a bit of knowledge from lurking and participating here :yesnod:
To A bad spark plug story ! ! !
Old May 20, 2003 | 08:07 PM
Mikez40's Avatar
Mikez40
For the AC Delco plugs:
'92 Lt-1- (41-904)
'93-95 Lt-1 (41-906)
'92-'95 ZR-1 - (41-913)Lt-5
Old May 20, 2003 | 10:43 PM
KyleBst264's Avatar
KyleBst264
I installed AC-Delco Rapid Fire spark plugs in the spring. Car is running good and I've had no problems with them.
Old May 20, 2003 | 11:12 PM
jefft84's Avatar
jefft84
Default Re: A bad spark plug story ! ! ! (KyleBst264)
Let me throw this into the mix for you Bosch haters and Delco only people. Take a look at your delco plugs if the print and stripe are blue they are made by a/c delco probably in Brazil ( in the American part I am sure:lol: ) if the print and stripe are green they are made by Champion (AKA the chrysler plug people)
