'85 Thottle Body question
Old May 19, 2003 | 09:06 PM
rsafier's Avatar
rsafier
Default '85 Thottle Body question
Quick question for all of you, does the 85 stock throttle body have one or two vacuum ports on the passanger side? The reason I ask it because I am going to get a new throttle body ported to 52mm, but don't have access to my car as the moment to look. I am going to have David Koldos do the work, I know a couple other members has had him do work, and they highly recommended him. Only thing is he needs to know this information.
Thanks in advance.
[Modified by rsafier, 11:39 PM 5/19/2003]
Old May 20, 2003 | 01:10 AM
Bluevette85's Avatar
Bluevette85
Default Re: '85 Thottle Body question (rsafier)
I just installed one from David and will be sending back my original 85 throttle body. 85 had only one vacuum port on the passanger side of the throttle body. It doesn't matter though because you can plug the extra hole with a vacuum cap and the later throttle body will work.
Old May 20, 2003 | 04:15 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I don't recall any vaccuum ports on the sides of the TB. There is one underneath it, but that's it. Are you talking about the plenum?
Old May 20, 2003 | 07:58 AM
Bluevette85
Default Re: '85 Thottle Body question (CentralCoaster)
The port goes to the valve cover breather.
Old May 20, 2003 | 11:00 AM
Jim85IROC's Avatar
Jim85IROC
Default Re: '85 Thottle Body question (Bluevette85)
It's not a vacuum port though. It's a fresh-air supply to the PCV system.
Old May 20, 2003 | 11:35 AM
MrNuke's Avatar
MrNuke
Default Re: '85 Thottle Body question (Jim85IROC)
The port goes to the valve cover breather.It's not a vacuum port though. It's a fresh-air supply to the PCV system.
:iagree:
To '85 Thottle Body question
