Shifter Knob Removal
Old May 20, 2003 | 08:06 AM
ZQQM's Avatar
ZQQM
Default Shifter **** Removal
How do I remove the shifter **** on my 91 automatic?
I want to replace the shifter boot. Thanks :steering:
Old May 20, 2003 | 10:57 AM
YellowYbody's Avatar
YellowYbody
Default Re: Shifter **** Removal (ZQQM)
Pry the button off with a screwdriver (carefully) then look down the button shaft, there is a round retaining clip at the bottom interior of the **** (I said **** :lol: ) Use a screwdriver to spread this retainer loose and the **** will lift right off.
Old May 20, 2003 | 11:33 AM
okinawa86vette's Avatar
okinawa86vette
Default Re: Shifter **** Removal (YellowYbody)
I agree, but with one difference. The retaining clip is designed to be removed with a snap ring plyers. It is well worth picking one up for 5 or 10 bucks. It should have a couple heads with it, use the one that spreads when you close the handles. It makes it a lot easier.
Chris
Old May 20, 2003 | 01:03 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Shifter **** Removal (okinawa86vette)
Chris
:iagree:
To Shifter Knob Removal
