PKE locks with key in ignition
Old May 20, 2003 | 07:00 PM
shepsvettes's Avatar
shepsvettes
Default PKE locks with key in ignition
The PKE on my 93 locks the doors with the key in the ignition. It didn't do this last year now I have to carry a second key with me incase it locks me out. Any ideas why it is doing this????? :confused: :confused: :confused:
Old May 20, 2003 | 07:10 PM
Lone Ranger's Avatar
Lone Ranger
Default Re: PKE locks with key in ignition (shepsvettes)
Dunno but mine did it once. Fortunately it happened @ home, so i fetched the spare PKE xmitter and unlocked it. Come to think of it, i think I replaced the little lithium watch battery in the PKE xmitter (transmitter) and it hasn't done it since.
Old May 20, 2003 | 07:25 PM
rocketfinger's Avatar
rocketfinger
Default Re: PKE locks with key in ignition (Lone Ranger)
This spring my PKE light came on when I hooked the car battery up so I replaced the transmitter battery and now it's gone completely goofy.
The fact that it can lock you in/out with the key in the ignition just reinforces my hatred for that wretched device.
Back in the good old days, you'd put a key in the lock and give it a turn...
Old May 20, 2003 | 07:34 PM
GoodbyeGirl's Avatar
GoodbyeGirl
Cruise-In III Veteran
Default Re: PKE locks with key in ignition (rocketfinger)
Why don't you disable it, then you can do that? :)
Old May 20, 2003 | 07:37 PM
KY Vette's Avatar
KY Vette
Hmmm, mine does this also.
But, if I forget and leave my key in the ignition and walk away, maybe that's a good thing.....? I mean, as opposed to a stolen car.
Old May 20, 2003 | 09:18 PM
merrick's Avatar
merrick
Default Re: PKE locks with key in ignition (KY Vette)
This might fix it https://www.corvetteforum.com/techti...=140&TopicID=2
Old May 20, 2003 | 11:10 PM
tuband's Avatar
tuband
Cruise-In I Veteran
The only times my '94 locked its doors with the key in the ignition I was NOT in the car. But thanks to having read here on the Forum what to do should that happen, I was not locked out.
Just shake the car and it will "wake" the PKE up and the doors will unlock. It's really cool .... everyone will think you're crazy but it does work.
Old May 20, 2003 | 11:16 PM
Patrick96LT4's Avatar
Patrick96LT4
Cruise-In II Veteran
Default Re: PKE locks with key in ignition (tuband)
:iagree: :yesnod:
Old May 20, 2003 | 11:46 PM
KY Vette's Avatar
KY Vette
Default Re: PKE locks with key in ignition (Patrick96LT4)
So, if you leave the keys in the car, it's NOT supposed to lock? I'm going to have to read the manual again. Yesterday, my wife got out of the car to run into the store, I stayed in the car. The car locked almost immediately after she got out, with the keys still in the ignition but turned off.
Then I started testing. So far, shaking the car doesn't do anything. I've tried it more than once. I'll try the suggestion in the post above, but I have a brand new FOB I just got from GMpartsdirect.com. I'll post here if I figure out what's going on with it.
Edit: Ok, this time I tried shaking the car with the keys still in the ignition. It sounded like it tried to unlock the doors right away. Maybe that's the difference? When I had left them lying on the console, it didn't seem to work.
[Modified by KY Vette, 11:04 PM 5/20/2003]
Old May 21, 2003 | 10:22 AM
Rich_01659's Avatar
Rich_01659
maybe you need to clean your key. could be that it is not seeing the proper resistance.
To PKE locks with key in ignition
