Fuel Pump Replacement?
:eek::eek::eek:
[Modified by NBM LS1 M6, 7:46 PM 5/20/2003]
:eek::confused::(:confused::(:eek:
First get a fuel pressure gauge onto the Schraeder valve on the fuel rail to assure you indeed have no fuel pressure.
BTW, that Camaro looks like a beast. :yesnod:
Funny you should ask! I just got done replacing my pump/strainer and fuel filter in my '85. If I'm correct, removal and installation are the same on yours.
Mine was located in the gas tank, and was accessed by first removing the 4 torx screws at the fuel door, allowing removal of the door and panle. I then had to remove the rubber gasket around the filler (vacuum out all the debris from this area so it doesn't fall into the tank). After that, disconnect the relay and all the hoses (I had 3 hoses). Then there are 8 (?) 1/4" bolts that get removed. Once those are out, lift on the filler, and wiggle the assembly out. Remove strainer, remove pump, install new pump, then new strainer (a real pain in the u-no-what to get on), be careful not to rip the strainer, and then reverse the above directions to re-install.
Took me less then 1 hour to do it myself, and until then, had never done more than change oil and plugs in a Blazer.
I bought a Carter pump for $89, + $5 for strainer, and you have to replace the filter (WIX $13.99) as well (hope you have a l-o-w floor jack), or the warranty is voided. All said and done, was less than $110, tow bill not included (argh).
FYI - AC/Delco FP was anywhere from $70 - $90 at my local parts stores.
If you go with Carter, you may need to splice the wiring, but easily done with a crimp.
Before doing all of the above, remember to release the gas line pressure at the Schrader valve, or else you'll smell like gas for a week.
Good Luck, and DON'T pay a mechanic for this if your setup is the same as mine.
By the way, first thing I bought when I got my C4 (Saturday), was a Haynes/Chilton manual for the car. Well worth the $$$ at twice the price.
The engine started on the first crank without ever touching the gas pedal. It idled for about three to five minutes, and then killed. I started it again just enough to move the car forward five feet back to its parking spot. Does that sound like the regulator or the pump itself?
:confused::confused::confused:
