Need a battery!!
Old May 24, 2003 | 10:19 AM
kingcono's Avatar
kingcono
Cruising
Default Need a battery!!
I have an '89 vette and would like to know a good battery to install. The one in their does not hold a charge for very long. I need a good one to also keep up with a nice sound system that was just installed. If anyone can recommend a good one, please let me know. Thanks!!! :seeya
Old May 24, 2003 | 10:48 AM
myscx's Avatar
myscx
Default Re: Need a battery!! (kingcono)
I just put a Die Hard Gold in, works great! :D
Old May 24, 2003 | 01:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I agree, I have a Die Hard in my IROC and it has performed well.
When the time comes one will go into my Vette.
Old May 24, 2003 | 04:32 PM
don hall's Avatar
don hall
Die Hard here, also. I would recommend spending an extra $10 for the "gold" series for the added warranty. Check it out, you decide. Just replaced a Die Hard in my PU after 9 years. Not because if failed; it just didn't owe me anymore.
Old May 24, 2003 | 05:16 PM
HG's Avatar
HG
Default Re: Need a battery!! (Oldman)
Ditto, go for the best. Did you ever change the battery in your vette? :cuss
Old May 24, 2003 | 07:03 PM
VETHEAD JR's Avatar
VETHEAD JR
Default Re: Need a battery!! (HG)
only go with the best. DIE HARD
:seeya :flag :seeya
Old May 24, 2003 | 07:12 PM
c4cruiser's Avatar
c4cruiser
DieHard Gold is a good battery at a reasonable price. If your audio system is going to use a fair amount of current, consider finding the highest rated capacity you can for a Group 75 battery (that's the group size that will fit in the tray. Something in the 850 to 1000 cold cranking amps range.
If you want an AC Delco, the 75-7YR battery has a cca rating close to those numbers. Also consider an upgraded alternator that will provide enough amps to run the load and also keep the battery up.
I think there was a thread awhile back that dealt with an upgrade kit that raised the output capacity of the stock alternator to provide 150+ amps. Check in the Audio Forum or do a search on "alternator" or "battery"
Old May 26, 2003 | 10:01 AM
Rick92's Avatar
Rick92
Die hard gold here too! :cheers:
To Need a battery!!
