Decoding help from a build sheet
Old May 28, 2003 | 12:23 PM
Kyle69-71 BBs's Avatar
Kyle69-71 BBs
Default Decoding help from a build sheet
Can anyone help with decoding this build sheet........
vin# 1G1YY32P3S5101989
ag1 ag2 ak5 ar9 bgr c05 c68 dl5 dl8 fe1 fe9 gmb 1p3
j55 kg9 lt1 ml9 mn6 na5 nk4 qb6 r7a r8t uxo uif u52
u75 vm3 v73 v73 xaa yaa 1ay 1sd 41t 41u 64i 643
bc/cc wa- ub555 41t 643
I am trying to figure out exactly which options this car has... Thanks Kyle
Old May 28, 2003 | 12:59 PM
Scoob's Avatar
Scoob
Default Re: Decoding help from a build sheet (Kyle69-71 BBs)
RPO Code Description
AG1 ADJUSTER, FRT ST, POWER, 6 WAY DRIVER
AG2 ADJUSTER, PASS ST POWER, 6 WAY
AK5 RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
BGR BOWLING GREEN PLANT PROCESSING
C05 ROOF, CONVERTIBLE FOLDING
C68 HVAC SYSTEM, AIR CONDITIONER FRT AUTO, ELECTRONIC
DL5 DECAL, ROADSIDE SERVICE INFORMATION
DL8 MIRROR, O/S LH & RH REM CONT, ELEC, DEFOG
FE1 SUSPENSION SYSTEM, SOFT RIDE
FE9 FEDERAL EMISSIONS CERTIFICATION
GM3 AXLE REAR, 3.45 RATIO
IP3 Trim, Interior Design (P3) (Base w/AR9)
J55 BRAKE SYSTEM, HEAVY DUTY
KG9 GENERATOR, 140 AMP
LT1 ENGINE, GAS, 8 CYL, 5.7L, MFI, HO
ML9 TRANSMISSION, MAN 6 SPD, ZF, 90UM, 2.66 IST, O/D
MN6 TRANSMISSION, MAN 6 SPD, ZF,
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NK4 STEERING WHEEL, SPORT LEATHER
QB6 WHEEL, 17 X 8.5 FRT X 9.5 RR, ALUMINUM, STYLED
R7A CONTROL, SALES ITEM NO. 26
R8T Invoice, Preliminary
UX0 SPEAKER SYSTEM, 4, DUAL FLR SILL, DUAL EXTD RANGE
U1F RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV MUSIC
U52 CLUSTER INST, ELECTRONIC
U75 ANTENNA, POWER, RADIO
VM3 LABEL INFORMATION, CONSUMER, CONTAINS BPR IMP STANDARD FOR
V73 VEHICLE STATEMENT US/CANADA
XAA TIRE FRONT, P255/45ZR17 BL R/PE ST TL HW4
YAA TIRE REAR, P285/40ZR17 BL R/PE ST TL HW4
1AY ORDER MODIFICATION STOCK (ordered for dealer stock)
15D TRIM COMBINATION, CLOTH, MED SLATE GRAY (D) (91)
41T TOP COLOR, BLACK (91)
41U PRIMARY COLOR, EXTERIOR, BLACK
64I INTERIOR TRIM, LIGHT BEIGE (I) (92)
643 TRIM COMBINATION, LEATHER, LT BEIGE (3) (92)
64S ROOF COLOR, BRONZE, REMOVABLE PANEL
Old May 28, 2003 | 01:19 PM
Kyle69-71 BBs
Default Re: Decoding help from a build sheet (Scoob)
Thanks Scoob :yesnod: :cool:
Old May 28, 2003 | 01:48 PM
Scoob's Avatar
Scoob
No problemo!
bc/cc - this means base coat / clear coat paint
wa- ub555 - this is the actual paint color code you'd need if you wanted to buy some touch up paint, for example
Old May 28, 2003 | 05:16 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
cool work Scoob..........
:thumbs:
To Decoding help from a build sheet
