Air Filter Replacement Update
Old May 28, 2003 | 07:24 PM
Sprongs's Avatar
Sprongs
Default Air Filter Replacement Update
Just wanted to say Thanks to those of you who took the time help me in finding out how to change the filter. Made it so much easier with your knowledge.
Now that I am ready to change it one last question, is a K&N filter worth the extra money or should I just stay with what was in the Vette, an AC A1097C?
Thanks in advance.
[Modified by Sprongs, 12:29 AM 5/29/2003]
Old May 28, 2003 | 08:03 PM
hngacurv's Avatar
hngacurv
Default Re: Air Filter Replacement Update (Sprongs)
K&N
Old May 28, 2003 | 08:42 PM
SeanSullivan's Avatar
SeanSullivan
K&N
Old May 28, 2003 | 09:45 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
A K & N will not flow any better than a new, clean stock element.
A K & N will flow better, clean or dirty, than a dirty stock element.
You won't have to replace the K & N.
..But you WILL have to clean it! :cuss
Larry
code5coupe
:seeya
Old May 28, 2003 | 09:47 PM
Patrick96LT4's Avatar
Patrick96LT4
Cruise-In II Veteran
Default Re: Air Filter Replacement Update (rocco16)
:iagree: K&N is no better than new, that's my opinion. But, it's a keeper forever if you clean it, where a paper filter would need to get tossed.
Old May 28, 2003 | 09:50 PM
Dark-Knight's Avatar
Dark-Knight
K&N
Old May 29, 2003 | 03:48 PM
90coupewithlowmiles's Avatar
90coupewithlowmiles
Cast another vote for k&n.....
Old May 29, 2003 | 04:27 PM
rocketfinger's Avatar
rocketfinger
Larry
code5coupe
:seeya
I've heard they flow worse than a paper element once they've been cleaned. I use 'em anyway.
Old May 29, 2003 | 04:54 PM
OleDog's Avatar
OleDog
Default Re: Air Filter Replacement Update (rocketfinger)
What do you guys use to clean your K&N filters. I know K&N sells cleaner but couldn't you use something like denatured alcohol?
Old May 29, 2003 | 06:10 PM
EricJ's Avatar
EricJ
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Air Filter Replacement Update (OleDog)
You will need the K&N kit since the filter needs to be re-oiled once it has been cleaned in order for it to work properly.
To Air Filter Replacement Update
