C4 Photosensor
Old Jun 20, 2003 | 03:06 PM
gregfloyd's Avatar
gregfloyd
Default C4 Photosensor
Hi all.
I have a 1990 vette. The little photo sensor that controls the daylight dash brightness is going bad i think. Has anyone ever replaced this? Can i just buy the sensor somewhere. I would hate to replace the whole DIC. Everything else on the unit works fine.
Any help would be appreciated.
Old Jun 20, 2003 | 06:46 PM
blk90rdstr's Avatar
blk90rdstr
Default Re: C4 Photosensor (gregfloyd)
I replaced mine because the plastic dome was missing. It is an easy fix. I dont know where you would get one. Mine came from Contemporary Corvette. That should do the fix.
Old Jun 20, 2003 | 07:08 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
I believe that's a discontined part. Corvette boneyard would be your best bet. What makes you think it's going bad? Best way to check is to test it at night, in the dark. Turn the key on to illuminate dash. Leave your headlights off. Shine a flashlight at the photocell, and the dash should get brighter.
Old Jun 20, 2003 | 07:34 PM
BAM92's Avatar
BAM92
Default Re: C4 Photosensor (flyersfan1088)
Or just cover it up and see if it gets brighter.
Old Jun 21, 2003 | 11:42 AM
Mikesa's Avatar
Mikesa
Where is this Photosensor located, and do I have one on my 92 ? There is a "sunload sensor" on top of the dash, in the defroster vent, but I'm pretty sure that's part of the electronic AC system.
Old Jun 21, 2003 | 11:43 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
Default Re: C4 Photosensor (BAM92)
:iagree: :thumbs: :iagree:
Old Jun 21, 2003 | 12:07 PM
CMYC4GO's Avatar
CMYC4GO
Default Re: C4 Photosensor (*89x2*)
If you cover it up, the dash will get dimmer, unless you turn on the lights. I know it doesn't make sense, but the dash will think it's night, and basicly dim out all the way until you turn on the lights. I think the instrument cluster is supposed to be super dim at night without lights on so when you're sitting in your Vette, and spying on your girlfriend's house, the dash won't illuminate the entire passenger compartment so she can see you. :lol:
Makes sense to me! :thumbs:
Old Jun 21, 2003 | 03:25 PM
SharkB4C4's Avatar
SharkB4C4
Default Re: C4 Photosensor (Mikesa)
Right above the gauge buttons on the right side of the dash--the 3/16" hole with clear plastic.
Old Jun 21, 2003 | 07:04 PM
KyleBst264's Avatar
KyleBst264
I've seen that on mine. What is the purpose of it? What does it do? I always thought it was a fastener to hold down the panel for the defroster vent.
Old Jun 21, 2003 | 08:23 PM
Mikesa's Avatar
Mikesa
Default Re: C4 Photosensor (KyleBst264)
The sunload sensor is one of three sensors in the C68 Electronic AC. It measures the amount of heat generated from the sun shining into the vehicle. There are two other sensors, one for outside temperature and one for interior temp. All three of these sensors feed info to the AC system.
Old Jun 22, 2003 | 05:02 AM
KyleBst264's Avatar
KyleBst264
Thanks Mike.
Kinda makes me pray that none of the stuff on the electronic climate control breaks. :lol: :lol:
To C4 Photosensor
