1992 digital speedo cluster
Old Jun 29, 2003 | 01:56 PM
red92vert's Avatar
red92vert
Default 1992 digital speedo cluster
MY CLUSTER STAYS LIT (ORANGE) BUT SOMETIMES LOOSES ALL INFO ON THE DISPLAY. IF I HIT A BUMP IN THE ROAD, OR FOR NO REASON, THE INFO COMES BACK ON. PLEASE HELP! THANKS. :confused:
Old Jun 29, 2003 | 03:20 PM
mitymek's Avatar
mitymek
Default Re: 1992 digital speedo cluster (greenlt1)
start checking connections.sounds like you got a loose one somewhere.
i'd start at the batt compartment and work to the firewall,then over to the fuse panel and seat all fuses there.
got any weight hanging on the key?switch could be going out. try a piece of tape pulling on the ignition and see if that stops it...
erratic electrical can be a nightmare.
i hope someone here has had the identical problem.
have you checked for codes yet?
Old Jun 29, 2003 | 04:52 PM
vette92_1's Avatar
vette92_1
Mine did the same thing, it was one of the soldered connections on the back of the electrical board of the cluster. I had the same symptoms as you've described. I re-soldered and have had no more problems with it, thats been about 4 years ago.
Old Jun 29, 2003 | 08:33 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
My 92 did the same thing it was the main connector that goes to the speedo all the connector were loose.
The fix was to "re crimp" the ends so they made a good contact with in the plug. :seeya
Old Jun 29, 2003 | 10:03 PM
red92vert's Avatar
red92vert
Default Re: 1992 digital speedo cluster (vette92_1)
was it much of a pita to open up the dash cluster area?
do you absolutely have to disarm the air bag system? :confused:
Old Jun 29, 2003 | 10:36 PM
grapeknutz's Avatar
grapeknutz
St. Jude Donor '06
Since I am slightly disabled (torn rotator cuff) I took it an shop that specialize in electrical problems, and yes they had to take the dash down :cry
Old Jun 29, 2003 | 11:45 PM
vette92_1's Avatar
vette92_1
It wasn't to much of a pita, IMO. It might not be a bad idea to disarm the air bag, however I didn't.
Old Jul 10, 2003 | 10:49 PM
red92vert's Avatar
red92vert
Default Re: 1992 digital speedo cluster (grapeknutz)
was it pins that you re-crimped on the back of the digital display, or in the housing, and would it be better to solder these contacts?
i'm going into my dash this weekend to replace the heater core, so i figure to kill two birds with one stone since i'll be digging around this "funhouse" anyway.
thanks :eek:
To 1992 digital speedo cluster
