OIL TEMP DIFFERENCE !
Old Jul 5, 2003 | 09:54 AM
Cal Vette's Avatar
Cal Vette
Default OIL TEMP DIFFERENCE !
Digital reads 212 but analog shows approx. 120. I think that I trust the digital. Does any one else have a the same problem with their C-4 ? :confused:
Old Jul 5, 2003 | 10:19 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: OIL TEMP DIFFERENCE ! (Cal Vette)
the Sensor has 2 elements, replace that it might be causeing the problem
Old Jul 5, 2003 | 02:01 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Cruise-In IV Veteran
My analog gauges have been screwed up since I bought my car...I only check the digitals...your analog is obviously incorrect....let me add that I do check the oil pressure via analog...no choice... good luck
Old Jul 5, 2003 | 04:54 PM
Sandy S's Avatar
Sandy S
Mine does the same thing. I replaced the sending unit but that didn't help. So I just live with it.
Old Jul 5, 2003 | 04:55 PM
waterboy's Avatar
waterboy
On my 94 coupe around town it shows mostly 200-208. I put in a 160 thermostat and all my temp's came down a little,even on a long trip the Oil temp stayed around 205 or lower. It is really hot down here most of the year.
Old Jul 6, 2003 | 04:57 AM
Dudule's Avatar
Dudule
My 92LT1 does exactly the same...I only check the digital oil temp...
:auto:
Old Jul 6, 2003 | 11:25 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Before I go any further, the following applies to LT1 cars(possibly the 90-91 also due to having the same dash layout).
First off everyone. How do you know your analog gauge reads 120? The markings on the analog gauge are as follows:
1st mark(from left) is 100, the 2nd mark is 215, the 3rd mark is 250, the 4th is 285 and the 5th mark is 320.
So the range between the 1st and 2nd mark is too broad for you to guess a temp of 120. I only use the analog guage to see if I'm running real hot, if the needle approaches the shaded area, I will check the digital readout(which I normally leave it set on anyway). SO my guess is that there isn't anything wrong with the gauge or sender.
To OIL TEMP DIFFERENCE !
