Removing Emblems?
Jul 17, 2003 | 11:28 AM
Removing Emblems?
I bought a new gas lid emblem for my CE, and I wanted to know how do you guys recommend I remove the adhesive that is holding the old emblem to the car? I got the speed nuts off, but it is still stuck in the car by the two sided adhesive. THANKS :confused:
Jul 17, 2003 | 11:41 AM
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
Re: Removing Emblems? (Eric 96)
If you heat it with a hair drier it should loosen it.
Jul 17, 2003 | 11:48 AM
Spray some WD-40 on it to soften the glue and then use some fishing line to run under it to losen it up.
Jul 17, 2003 | 01:06 PM
Re: Removing Emblems? (Mikez40)
I got mine off by carefully slipping an old credit card between the emblem and the car body and working it back and forth.
Jul 17, 2003 | 01:19 PM
From: Isle of View "Mofo skated me, that was my up!"
Re: Removing Emblems? (Black89)
Dental floss, fishing line, wear gloves. :D
Jul 17, 2003 | 01:51 PM
Cruise-In IV Veteran
Spray it with GooGone from Home Depot. Let it soak in and pry it off with a credit card. The fishing line/WD 40 thing didn't work at all for me.
Jul 17, 2003 | 05:23 PM
NOT the way I did it!
You don't want to know... :nono:
Jul 18, 2003 | 07:41 AM
Thanks guys...I got it off with WD-40, Dental Floss, and a Credit Card. Now it is making the nose emblem look old...so I ordered one for the nose :cheers:
Jul 18, 2003 | 08:45 AM
A good screwdriver or a crowbar should do the trick ;) :jester
