'92 speaker replacement advice
Old Jul 22, 2003 | 11:10 PM
MYBLUEHEAVEN's Avatar
MYBLUEHEAVEN
Default '92 speaker replacement advice
Starting to get an intermittant buzz in the front left speaker on my '92. How do you access the speaker behind the carpet? Also do you just replace the speaker or do you need the amp? Thanks in advance, you all have helped me before, hope to return the favor someday.
Old Jul 22, 2003 | 11:36 PM
SPEED750's Avatar
SPEED750
Default Re: '92 speaker replacement advice (MYBLUEHEAVEN)
You pull off the door sill.I think it's like 5 screws,the speaker "grille" is built in to the sill.The amp is what makes most problems.If the buzz comes and goes, most likely it's the amp. :chevy
Old Jul 23, 2003 | 12:17 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: '92 speaker replacement advice (SPEED750)
Click this link below and print it out on a color printer preferably. These guys walk you right through it. I replaced all four of my amps about four weeks ago in less than ONE HOUR!
http://carstereohelp.com/stereoremovalCorvetteFspk.htm :thumbs:
To '92 speaker replacement advice
