I READ SOMEWHERE THAT YOU CAN RESET THE OIL CHANGE SIGNAL ON YOUR INFO PANEL BY PRESSING SOME SEQUENCE OF THE FUEL / GAUGE INFO BUTTONS ON THE DASH, ANYONE KNOW ?
THANKS, :chevy
turn key to on(don't start)
press ENG/MET, within 5 sec, press Eng/Met again
press and hold GAUGE for about 10 sec until you see the change oil light go out.
That's how it's reset on my 95, just did it yesterday
If you are having trouble make sure you do start the engine after every 2nd try or you will flood the engine. That is what I did.
