Help Please
Old Aug 5, 2003 | 04:06 PM
mustard's Avatar
mustard
Default Help Please
My backup and rear side lamps don't work. I put in a new bulb in the backup lites but that didn't do any good. I looked in my book and it says that the blinkers and backups are on the same fuse. My blinkers work just fine. Could I have a loose wire or something?
Thanks for your help
Musrtard
bogus's Avatar
bogus
Default Re: Help Please (mustard)
check the relays.... could also be a back backup switch.
[Modified by bogus, 4:07 PM 8/5/2003]
Old Aug 5, 2003 | 04:40 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Re: Help Please (bogus)
Sounds like the back up switch, they are known to fail :yesnod:
Old Aug 5, 2003 | 06:17 PM
mustard's Avatar
mustard
where are the relay switches? How do I check them? And where is the backup switch?
Old Aug 5, 2003 | 06:37 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
on a manual the back up switch is located on the left side of the trans (drivers) on an automatic I think it is located in the gear selector switch, this is in the console. the wire(s)
entering the gear selector switch are a dark blue feed from the fuse block & exit as a light
green feeding the back up & cornering lights. fuse is 15 amps and controls the back up
& cornering lights (this is on an 86 coupe)
To Help Please
