HELP!!!!!!!!!!!!!!!!!!!
Old Aug 7, 2003 | 07:01 PM
scorpion's Avatar
scorpion
Default HELP!!!!!!!!!!!!!!!!!!!
does anybody know the location of the fog lamp relay for a 95??????????????
Old Aug 7, 2003 | 08:38 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Default Re: HELP!!!!!!!!!!!!!!!!!!! (scorpion)
Man , I'm sorry! I just spent 25 min combing thru my parts on CD, and I can't find it anywhere! I'll keep trying. If I find it, I'll holler! :chevy
Old Aug 7, 2003 | 08:51 PM
SharkB4C4's Avatar
SharkB4C4
My Helms manual for 96 says "bottom right-hand side of instrument panel, in the relay retainer." The location for 95 may or may not be the same, but you might look there first.
Old Aug 7, 2003 | 09:15 PM
scorpion's Avatar
scorpion
Default Re: HELP!!!!!!!!!!!!!!!!!!! (SharkInShark)
does that mean it is on the passenger side?
:confused:
Old Aug 7, 2003 | 09:20 PM
SharkB4C4's Avatar
SharkB4C4
:confused:
Yes.
Old Aug 7, 2003 | 09:23 PM
scorpion's Avatar
scorpion
thanx guys!!!!!!!
Old Aug 7, 2003 | 09:25 PM
Red Dwarf's Avatar
Red Dwarf
95 manual says in relay container bottom right hand side, pass side.
Old Aug 7, 2003 | 09:31 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
Remove the passenger side kneepad to do this you will need to open the fuse panel and remove the 3-torx screws, there will be two more cap screws under it. Pull the passenger ac vent by popping the small center cover and removing two torx screws. You will see the 3- 10mm nuts remove than pull panel out and down. . Looking up from under the dash over to the left side or right as you are now upside down!! you will find a black cover about 2x4 remove it there are 4 to 6 relays
2 3 1
6 5 4
2 fog lamp, 3 courtesy lamp, 1 open
6 fuel pump 2 (lt5), 5 fuel pump 1, 4 horn relay
[Modified by We Gone, 9:36 PM 8/7/2003]
To HELP!!!!!!!!!!!!!!!!!!!
