A/C Going out
Old Aug 19, 2003 | 05:08 PM
Locke434's Avatar
Locke434
Default A/C Going out
How can I tell if my air conditioner is having problems. I can tell a it's still pushihng air through, little cold, but for from air conditioning., Also does anyone else have the same problems of if you park your car outside that it's gets entirely to damn hot inside, like so how that it might damage a radar detector or cd player? Is their a fluid I can replace or anything?
Old Aug 19, 2003 | 05:18 PM
Mikez40's Avatar
Mikez40
Default Re: A/C Going out (Locke434)
Sounds like you may be low on Freon. You should get it checked at a place that does AC work. You may have a leak in your system and that could get expensive.
good luck.
Old Aug 19, 2003 | 11:18 PM
yoslambo1@cs.com's Avatar
yoslambo1@cs.com
Default Re: A/C Going out (Mikez40)
:iagree:
To A/C Going out
