Bose stereo question
Old Aug 19, 2003 | 06:53 PM
corvette8585's Avatar
corvette8585
Default Bose stereo question
My dad recently picked up an 89 vette all original with about 30k miles. The car is in excellent condition and has the original bose stereo, however the stereo sounds a bit weak and doesn't pick up stations that well. then a few days ago the driver's side front speaker began making a high pitch noise that would "wind" down over a couple of minutes then you would here a constant high pitch gargle. would this be a problem with the speaker amp, the original head unit, or the some connection in between? :banghead:
Thanks,
Old Aug 20, 2003 | 10:25 AM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default Re: Bose stereo question (corvette8585)
Sounds like an antenna connection problem and an amplifier problem. Post this in audio/electronics for a quicker answer.
Good Luck!
Dan :thumbs:
Old Aug 20, 2003 | 10:27 AM
bogus's Avatar
bogus
the sound problem is a bad amp.
I guess the receiver module could be bad....
personnally, I hate bose. replace the damned thing.
Old Aug 21, 2003 | 02:39 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Bose stereo question (bogus)
Should you decide to keep the Bose, contact Dr. Don's at
http://www.doctordons.com/boseradios.htm :thumbs:
Reasonable and excellent quality work!
[Modified by onedef92, 2:39 PM 8/21/2003]
Old Aug 21, 2003 | 03:01 PM
Strick's Avatar
Strick
Default Re: Bose stereo question (onedef92)
:iagree: Doctor Don's :thumbs:
Old Aug 21, 2003 | 06:36 PM
1989redvette's Avatar
1989redvette
save your money now and dump the blows system and invest in a quaility system at a fraction of the cost!! been down your road only to end up getting a better system..and i might it add it sounds incrediable!!
Old Aug 21, 2003 | 06:52 PM
Pilot_1's Avatar
Pilot_1
I agree with the rest....I had a similar experience with the same symptoms and found it more expensive to repair. I pulled it out and replaced it with a new Eclipse, new wiring harness and speakers. It should last for a very long time.
Old Aug 21, 2003 | 07:57 PM
redvettetuck's Avatar
redvettetuck
Cruising
Default Re: Bose stereo question (brdd)
There is a guy in texas that rebuilds the amps. about $50.00 I live in NYC
This radio system is very dissapointig
To Bose stereo question
