Clutch problem on 93 Vette
Old Aug 22, 2003 | 01:54 PM
Jimbo93's Avatar
Jimbo93
Default Clutch problem on 93 Vette
I was just slowing down for a stoplight the other day, and stepped on the clutch and brake, an dI just instantly lost all pressure in the clutch peddle.
I had to start it in 1st and shift without the clutch to get home, and the clutch is just fine, I just lost the peddle. It doesn't stay on the floor, there is just very little resistance. Anyone have an idea what could be wrong? Thanks :seeya
Old Aug 22, 2003 | 03:06 PM
QuikZilver's Avatar
QuikZilver
Default Re: Clutch problem on 93 Vette (Jimbo93)
Check your fluid level. Your slave cylinder may have gone out on you.
Old Aug 23, 2003 | 02:23 AM
BAM92's Avatar
BAM92
Default Re: Clutch problem on 93 Vette (Whitvette)
Check for fluid leaking at the clutch cylinder. If ok there check to see if you have fluid where rod goes into clutch master above the pedals.
Old Aug 24, 2003 | 06:01 PM
mik's Avatar
mik
Had the same problem on my 94. It was a bad slave cylinder. All the fluid leaked out.
Old Aug 25, 2003 | 09:11 AM
Jimbo93's Avatar
Jimbo93
Ya, I checked the fluid level, and it was empty. It's probably the slave cylinder. Does anyone know anything about changing one of these?
Old Aug 25, 2003 | 09:53 AM
mitchcole's Avatar
mitchcole
It's easy. Standard hydraulic connections. Just pull, replace, and bleed. Much easier than brakes because the run is short with lots of slope and only one connection. I did it on an RX-7.
It's just a little messy. (perhaps not since all your fluid is gone.)
Good luck!
Old Aug 25, 2003 | 10:09 AM
Sawbone's Avatar
Sawbone
Your best bet is to change the Clutch master cylinder, slave actuator, and hydraulic line as a set. The install is easy, bleeding the system can try your patience but it isn't difficult.
Old Aug 25, 2003 | 10:58 PM
Mystic '95's Avatar
Mystic '95
Cruise-In II Veteran
Default Re: Clutch problem on 93 Vette (1995LT1)
I had same problem 2 years ago, it was the slave..
Old Aug 26, 2003 | 10:08 AM
Jimbo93's Avatar
Jimbo93
Hey, thanks for the info guys. It's in the shop right now, (it was fun driving it there without the clutch, ya right), but I made it. Will get prognosis tomorrow.Will let you know after that. Thanks again! :seeya
To Clutch problem on 93 Vette
