Manuals
Old Aug 30, 2003 | 04:04 PM
Vette Head's Avatar
Vette Head
Default Manuals
Ok, I have Haynes, Chilton, and GM Shop Manuals. What about the Helm? Which do you use, and why? Is there a difference between the Helm and the GM Manual, and which is better if there is?
:seeya
Old Aug 30, 2003 | 04:22 PM
04Z16's Avatar
04Z16
CI 3-4-5-6-7-8-9-10 Veteran
Default Re: Manuals (Vette Head)
I find the GM Shop manaul to be correct where in the past the Helms and Chiltons have had wrong information.
Old Aug 30, 2003 | 07:28 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My prime reference is the set of GM Shop Manuals; sometimes I refer to the Haynes but it is not nearly as rich in detail and information.
I also have several volumes on TPI theory & trouble shooting along with several on SBC building and a Comp Cams catalog which are valuable when planning mods.
Old Aug 30, 2003 | 07:58 PM
JCAIRE2's Avatar
JCAIRE2
Um aren't the GM shop manual and Helms manual one in the same? :confused:
Either way, I have all the manuals I've been able to find for my year, and the GM Shop(what I thought was the same as Helms) is by far the most detailed.
Old Aug 31, 2003 | 07:31 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Manuals (JCAIRE2)
Yes they are and you can't beat them for the amount of info that's in there.
Old Aug 31, 2003 | 10:04 AM
RichS's Avatar
RichS
Default Re: Manuals (Mr Mojo)
I buy a Helms for all the Vettes we buy.
Old Aug 31, 2003 | 10:13 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Re: Manuals (RichS)
Helms does not make manuals, per se. They sell the factory General Motors manuals and, I believe, are GM-authorized to reprint old, out-of-print GM manuals.
For instance, they sell old owner's manuals for Chevys. I got one for my son when he bought an old ('78?) 4x4 chevy pickup.
Helms probably sells manuals for other makes, but I'd have go to Helm's website to verify this, and I have to get ready for church.
Larry
code5coupe
:seeya
Old Sep 1, 2003 | 12:21 AM
Mr Mojo's Avatar
Mr Mojo
Default Re: Manuals (rocco16)
In my owners manual it says to go to Helms for the service manuals.
Old Sep 2, 2003 | 12:04 AM
Sam Lam's Avatar
Sam Lam
I agree that a GM Service manual is a Helms manual. Got this straight from the Corvette Museum at BG and for using them for 30 years!
Old Sep 2, 2003 | 06:44 PM
vader86's Avatar
vader86
Haynes is crap, total waste of money, never enough info on how to do something.
Got to go with GM/Helm
Old Sep 2, 2003 | 07:35 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Manuals (vader86)
UPS just delivered my Helms shop manual today. Need three binders though...too thick for one. But it looks like toooooo much good info. :yesnod:
Old Sep 2, 2003 | 08:12 PM
rocco16's Avatar
rocco16
Default Re: Manuals (Sam Lam)
[QUOTE]I agree that a GM Service manual is a Helms manual. [QUOTE]
Backwards.
The manual sold (and probably published) by Helms is the GM Service Manual.
I'm looking at my GM manual, purchased from Helms. The title page says "copywrite 1995 General Motors Corporation.....No part of this publication may be.....without the prior written permission of General Motors Corporation."
Nowhere in the manual is the name Helms found. If it's a "Helms Manual", why is GM claiming all rights to its contents?
You may be confident that the manual sold by Helms is the genuine GM Service Manual.
Larry
code5coupe
:seeya
Old Sep 3, 2003 | 10:23 AM
jmrl98's Avatar
jmrl98
GM/Helms for first resource, the Chilton's is backup resource. :seeya
Old Sep 3, 2003 | 10:54 AM
Xenocide's Avatar
Xenocide
Totally agree with you. Haynes and Chilton have never been helpful to me. They gloss over WAY too much.
Typical Haynes repair procedure:
How to replace clutch in manual transmission cars:
Step 1: Drain transmission fluid.
Step 2: Remove transmission.
Step 3: Install new clutch.
Step 4: Reinstall transmission and replace fluid.
Step 5: Procedure complete.
It's literally almost that bad.
Old Sep 3, 2003 | 11:51 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Re: Manuals (Xenocide)
chilton's is the worst. i always start reading it and then end up coming here.
Old Sep 11, 2003 | 03:17 PM
Q1KSLVR's Avatar
Q1KSLVR
:yesnod: Usually the aftermarket manuals get their info from GM manuals.
Old Sep 11, 2003 | 03:55 PM
QuikZilver's Avatar
QuikZilver
Default Re: Manuals (Q1KSLVR)
I use all three. I use the Haynes and Chiltons to get an overview of what I am going to be getting into. Then I break out the GM Service Manual to actually work with, unless the Haynes or Chiltons has the same picture I need (wire numbers on distributor, for example). Then I break the other manual out so as not to get my Service Manuals too greasy! :lol:
Old Sep 11, 2003 | 10:10 PM
MIke350's Avatar
MIke350
Default Re: Manuals (Whitvette)
i use both the gm and the Chiltons for different points of view and some different angles of pics. the gm manual is worth its weight in gold to me :smash:
To Manuals
