Hood Problem
Old Sep 2, 2003 | 08:51 PM
vettevibe9203's Avatar
vettevibe9203
4th Gear
Default Hood Problem
Hey guys just got my first vette. Problem is hood release not working, feels like it release on passenger side but not drivers side. Is there anything I can do or do I need to take it to the shop?
Old Sep 2, 2003 | 09:10 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: Hood Problem (vettevibe9203)
there is a hood opening tool that you can get from the major catalog houses. but if you do a search on hoods you will find a lot of information. Many have posted on this subject.
:thumbs:
Old Sep 2, 2003 | 09:50 PM
HG's Avatar
HG
Did you try holding the release lever out and have someone pull on the hood. This may work. If it does. clean both locks of all of the grease as well as the hood pins. Put a small coating of silicone grease on the hood pins and locks. This usually works. Check the release cables, they are adjustable. If not, you need the tool in the Mid America book to open the hood.
Old Sep 2, 2003 | 10:03 PM
jerseyvette's Avatar
jerseyvette
Default Re: Hood Problem (HG)
:iagree:
Old Sep 2, 2003 | 10:45 PM
KyleBst264's Avatar
KyleBst264
Default Re: Hood Problem (scottyj33)
:iagree:
:iagree: Saved me alot of typing. I would've said the same thing.
Old Sep 2, 2003 | 11:26 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Default Re: Hood Problem (KyleBst264)
Do some reading up on this in the search area. The hood opening tool is not always the answer to these hood problems.
[Modified by 2nd2SEX, 10:26 PM 9/2/2003]
Old Sep 3, 2003 | 01:35 AM
mitymek's Avatar
mitymek
hello! congrats on the ride.im bettin youll find ample info at your disposal right here to fix that hood and anything else on your car right here.
your gonna love this place.
:cheers:
Old Sep 3, 2003 | 07:22 AM
C-4 Cross Fire's Avatar
C-4 Cross Fire
Do NOT, NOT, NOT pull on the hood!!! The corners of the hood near the windshield where you're pulling are prone to stress fractures--you WILL crack your paint--do NOT pull on the hood. If your cables are out of adjustment more than 1/8 of an inch you will have this problem--so BUY A TOOL to open your hood before you crack the paint...like I did :nonod: :sad:
Good luck--I hate when this happens.
Old Sep 3, 2003 | 09:27 AM
vettevibe9203
4th Gear
Default Re: Hood Problem (C-4 Cross Fire)
Thanks for the info guys. Looks like I will need alot more help in future. Got a great deal on the car (I think) but it does need a little of this and a little of that. Guy who owned it before just used the car never did a thing for it.
This sound like a great forum to be a part of. Thanks again.
Old Sep 3, 2003 | 09:38 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Search for "Hood" - sure you'll find your answer here...Great Place & Welcome abord...
Old Sep 3, 2003 | 01:17 PM
ZR-71's Avatar
ZR-71
St. Jude Donor '15
Welcome to the Forum :cheers:
Lots of helpful info and comraderie here.
Old Sep 3, 2003 | 01:19 PM
subman's Avatar
subman
Default Re: Hood Problem (ZR-71)
:seeya Hi and welcome! :seeya
Old Sep 3, 2003 | 01:51 PM
froggy3k's Avatar
froggy3k
Your days are not going to be the same. Remember to get off this site and enjoy your vette sometimes. Questions? You've found the hot spot with answers!
Welcome!
:thumbs:
To Hood Problem
