Speed bleeder, which size?
Old Sep 3, 2003 | 07:04 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Speed bleeder, which size?
Jegs lists speed bleeders in many different sizes. Anybody know which size fits a 92 vette?
Old Sep 3, 2003 | 10:04 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Default Re: Speed bleeder, which size? (Nathan Plemons)
They were able to look them up at Autozone down here in Fl. They were the cheapest at $10 per pair too.
Old Sep 3, 2003 | 10:10 PM
HammerDown's Avatar
HammerDown
Here you go, Nathan.
http://www.speedbleeder.com/size.htm
You want part # SB1010
Incidentally, I don't think the speed bleeders sold in Auto Zone are as good as the original Speed Bleeders on that website. I bought a brand new set from Autozone last brake flush/bleed, and one leaked like crazy.
[Modified by HammerDown, 9:11 PM 9/3/2003]
Old Sep 3, 2003 | 11:07 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I bought the speedbleeders from Mid America.
So is that OK?
tony
Old Sep 4, 2003 | 09:41 PM
c4cruiser's Avatar
c4cruiser
Default Re: Speed bleeder, which size? (HammerDown)
SB1010 is the right one for C4's. You should get the kit with the hose and bleeding bag as it helps with bleeding at the track. You don't have to carry a bottle or can with you. Also get the small bottle of thread sealant at the same time. The sealant should be replaced after you open and close the bleeders a number of times. https://www.speedbleeder.com/install.htm
There are a number of bleeders on the market that work in the same fashion. Russell sells them. Speed Bleeder is a trademarked name and the design is patented so just because you see "speedbleeder" in a catalog, it doesn't mean that you are getting them from the company called Speed Bleeder Products.
Old Sep 4, 2003 | 09:54 PM
SPEED750's Avatar
SPEED750
Its a 10mm. :seeya
Old Sep 5, 2003 | 12:07 AM
Corvette0096's Avatar
Corvette0096
Default Re: Speed bleeder, which size? (SPEED750)
Its a 10mm. :seeya
:iagree:
Old Sep 5, 2003 | 12:22 AM
JasonL's Avatar
JasonL
Its a 10mm. :seeya
10mm x 1.0mm to be exact.
Old Sep 5, 2003 | 05:28 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
Default Re: Speed bleeder, which size? (oldace84)
So is that OK?
tony
Yes Tony, that's ok.
They're M10 x 1.0, as already mentioned.................
To Speed bleeder, which size?
