Retorque heads procedure
Old Sep 5, 2003 | 11:23 AM
vettmanlt4's Avatar
vettmanlt4
Default Retorque heads procedure
My hew AFR heads have about 200 miles on them I suppose I should
retorque heads. (PIA)
Whats the correct procedure to retorque my new heads.?
Do I contiue clockwise or do I loosen bolts and retorque to specs.
[Modified by vettmanlt4, 10:23 AM 9/5/2003]
Old Sep 5, 2003 | 11:37 AM
LD85's Avatar
LD85
Default Re: Retorque heads procedure (vettmanlt4)
This is a much debated subject for sure,
but when I did mine, I had to remove the headers and then started in the center and loosened one bolt, then retighted that same bolt, then went clockwise to the next bolt at 1:00 then did the same in a spiral fashion.
I hope i did not confuse you.
[Modified by ld85, 11:43 AM 9/5/2003]
