C4 Exaust Tips?
Old Sep 17, 2003 | 03:00 PM
Its-Me's Avatar
Its-Me
Default C4 Exaust Tips?
I am not overly firmiliar with the exaust system of my C4. But I keep seeing cool tips on other Vettes.
Can a guy just change the tips from the rectangular style to another?
Old Sep 17, 2003 | 03:30 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
Default Re: C4 Exaust Tips? (Its-Me)
If you have the ability to cut and weld tubing, the answer is pretty much yes. Otherwise, you may need to see a muffler shop. Most catalogs (Eckler's and MAD) cary different tips and numerous mufflers with unique designs. Check them out because there are many.
Good luck!
Old Sep 17, 2003 | 05:41 PM
hhvette's Avatar
hhvette
I bought a set of stainless tips for my 1994. You drill four small holes and you use four screws and washer which were included. They look a lot better than the normal tips. I know Corvettes of Houston have them all the time (sometimes on e-Bay). I bought mine at Corvettes of Dallas. They were about $60. :auto:
Old Sep 17, 2003 | 06:39 PM
HG's Avatar
HG
Had LT1's welded on, I like the look :cool:
Old Sep 17, 2003 | 07:43 PM
HapAFcop's Avatar
HapAFcop
Default Re: C4 Exaust Tips? (HG)
When I bought my car it had no tips installed at all. It has the stock exhaust setup. I bought the tips pictured below at Autozone for $5 each. I think they look pretty good. When I decide I want to fork over the $$$ to replace the exhaust I'll get better ones.
Old Sep 17, 2003 | 08:18 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
Had mine welded on :cool:
Old Sep 17, 2003 | 09:27 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Re: C4 Exaust Tips? (LT-4 CE)
If you have the ability to cut and weld tubing, the answer is pretty much yes. Otherwise, you may need to see a muffler shop Good luck!
:iagree:
A SawZall and a Millermatic and ANY tip is possible. Otherwise you are on your own. Crawl under your Corvette and you'll find out .....
(you mean you didn't do that FIRST???!!!)
Larry
code5coupe
:seeya
To C4 Exaust Tips?
