C4 Service
Old Sep 23, 2003 | 02:56 PM
vette64red's Avatar
vette64red
Default C4 Service
Sold my 64, and thru this forum bought a 94. Thanks, it's a beauty. I changed the oil and filter and now I am reading the shop manual on the coolant. One section says to remove the Knock plug, 1, and another section says to remove the left and right side Knock plugs. How many are there?
I am not sure I can handle the procedure to drain and refil the coolant but I am also very nervous about giving my new baby to a dealer.
Thoughts? :flag
Old Sep 23, 2003 | 07:56 PM
ductape's Avatar
ductape
Cruise-In V Veteran
Default Re: C4 Service (vette64red)
I'm not sure how similar my '85 and your '94 are in this department. I removed the hose on my oil cooler and flushed everything. I have been told to remove the knock sensor for the same. At any rate, you might want to post this in the Tech/Performance section too. And welcome!! :seeya
Old Sep 24, 2003 | 12:29 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: C4 Service (ductape)
I've been there. If you remove the knock sensors, be sure and torque them back in to spec. or you might get Code 43 Service Knock Sensor. I think the correct torque is 15 lbs. but double check your shop manual.
Also, don't add any plumbing tape or thread compound to the sensors. The stock orange coating that comes on them is sufficient. You can use a dedicated knock sensor tool like Craftsman or a box ended wrench or a socket/breaker bar combo.
The rounded part of the sensor's actually sturdy enough to support a pair of locking vice grips if you encounter a stubborn one that fails to respond to standard tools.
Next time, I'm thinking about simply using a shop vac and BLOW the coolant out of the system. Warm the engine to operating temp to open the stat, then open the black coolant tank and place the vacuum nozzle in the inlet.
With the hose on the BLOWER side of the shop vac, you can use air pressure to force all the coolant out and not have to worry about lifting the car and wrenchinig those sensors out.
Be sure and open the bleed screws when you're done adding fresh coolant to burp air pockets out of it! Good luck. :thumbs: :chevy
Old Sep 24, 2003 | 12:58 PM
warren s's Avatar
warren s
Default Re: C4 Service (onedef92)
I took out the thermostat, left the drain plug open on the radiator and stuck my garden hose in the radiator. Started it and let it run for about 20 minutes with the heat on and the hose in the rad on low pressure.
Washed everything out and didnt touch the knock sensors.
Old Sep 24, 2003 | 03:58 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: C4 Service (warren s)
:iagree:
Old Sep 24, 2003 | 05:29 PM
HapAFcop's Avatar
HapAFcop
I may be missing something here, but where does the coolant exit the system? :confused:
Old Sep 25, 2003 | 12:38 AM
Alex D's Avatar
Alex D
You don't have to blow the coolant out of the system. just drain it and remove the thermostat, insert a garden hose in to each of the flow paths in the thermostat housing (one to the left and one to the right) and backflush the whole thing for a fewe minutes until only clean water comes from the hose. Do the same with the radiator and refill. You will have replaced over 99% of teh coolant in the system this way with fresh coolant.
Old Sep 26, 2003 | 07:51 AM
onedef92's Avatar
onedef92
Default Re: C4 Service (HapAFcop)
Through the open radiator petcock and the water galleys around the block once the sensors are out of course. :lol:
Old Sep 26, 2003 | 07:53 AM
onedef92's Avatar
onedef92
Default Re: C4 Service (Alex D)
Yeah, but see if you BLOW it out, you'll get ALL of the old coolant out of there and you don't have to remove the thermostat or knock sensors. Do a fast-flush for about five minutes with Prestone or other brand and you'll get most of those calcium deposits and other crud out of there, too. That's all I'm suggesting. Obviously your method works, too. :thumbs:
To C4 Service
