is there any cheaper?
Old Sep 23, 2003 | 05:19 PM
88 L98's Avatar
88 L98
Default is there any cheaper?
I'm looking for coilovers and the only company who advertises them for the 88 is the DRM. it's $1600. is there any other companies that make a kit that is cheaper?
Old Sep 23, 2003 | 08:21 PM
Southern Comfort's Avatar
Southern Comfort
Default Re: is there any cheaper? (88 L98)
Be a cold day in hell before I spent 1600 bones on shocks. :bs
Old Sep 23, 2003 | 08:33 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Default Re: is there any cheaper? (Southern Comfort)
:iagree:
Old Sep 23, 2003 | 10:25 PM
88 L98's Avatar
88 L98
Default Re: is there any cheaper? (vinnies87)
not shocks, coilovers. and does anyone have any USEFUL info? :banghead:
Old Sep 23, 2003 | 10:48 PM
Gar's Avatar
Gar
Do you mean Coil spring kit? You see a coilover is a shock that has threads on it so you can adjust the ride height by raising or lowering a locking nut that the spring rides on. A kit would include the springs and shocks and hardware and on a Vette a conversion kit to mount it after you remove your stock monoleaf spring. It cost more for a Vette cause you are totaly changing the suspension from leaf spring to coil spring. QA1 sells a kit for pro street guys for about $500+
Old Sep 24, 2003 | 12:17 AM
88 L98's Avatar
88 L98
Default Re: is there any cheaper? (Gar)
thanks. I emailed them. hopefully they'll have some good info.
To is there any cheaper?
