Where is the starter???
Old Sep 25, 2003 | 07:25 PM
Butta's Avatar
Butta
Default Where is the starter???
Where is the starter on a 95 LT1, thanks.
Old Sep 25, 2003 | 07:44 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Where is the starter??? (Butta)
right side of the engine(passenger side)
Old Sep 25, 2003 | 08:19 PM
ZRWON's Avatar
ZRWON
MOJO, I thought the starter on the LT-5 was on top of the motor in back between the heads. I think I read about this and starter problems that many owners encountered in the 1991-1993 time frame. As I remember it many owners had to have starter replacements after they sprayed water in motor when cleaning them. Seems the water collected in the valley where the starter was mounted and shorted out the wiring??? As I remember starter replacemant was very expensive as you can imagine considering what a "QUALIFIED (certified) LT-5 Trained" mechanic had to remove just to access the starter. I was lead to believe it was not a job for a shade tree mechanic or corner gas station car repair outfit.
I'm lucky...never had starter problems on my LT-5 but never ever let any water get sprayer on my motor either. I'd all but forgotted the starter stuff until I read this post.
Maybe some of the folks in the ZR-1 forum can clarify this for us??? Bill :confused:
Old Sep 26, 2003 | 12:37 AM
Butta's Avatar
Butta
Default Re: Where is the starter??? (ZRWON)
It's a Coupe not a ZR1.
Old Sep 26, 2003 | 09:12 AM
FC2000's Avatar
FC2000
On the subject of starter replacement on LT-5.
While you do need to remove the plenum top and ignition coils, it is not difficult and any moderatly astute shadetree mechanic can do it in a couple of hours. It's these types of misconceptions that scare people away from the ZR-1. Currently the best bargin in used supercars today.(and no mine is not for sale!) :steering:
Old Sep 26, 2003 | 11:02 AM
redwing76's Avatar
redwing76
Default Re: Where is the starter??? (FC2000)
Starter is under the car where all the grime lives. Follow the battery cable.
The Northstar has the starter buried in the engine also. Good planing.
Thats right up there with the opti-spank.
GM's market share has fallen to 15% from a high of 50%. Good engineering is a lost concept at GM.
Old Sep 26, 2003 | 11:36 AM
FC2000's Avatar
FC2000
Default Re: Where is the starter??? (redwing76)
In reality, you have to blame the Britts for the starter position on the LT-5 as well as the Northstar.
Lotus did the original developement work on the LT-5 and the Northstar design is a direct relative.
Never forget that Lucas was the birth of all things electrical in Brittain! :crazy:
Old Sep 26, 2003 | 12:55 PM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
It’s in the spare tire carrier next to the jack. :jester
Old Sep 26, 2003 | 01:24 PM
Butta's Avatar
Butta
Default Re: Where is the starter??? (IBEAM700)
Now seriously, where is the starter for an LT-1, does anyone have a picture, please?????
Old Sep 26, 2003 | 05:06 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Al, you're making me work too hard. :lol: :steering:
Old Sep 26, 2003 | 06:09 PM
Butta's Avatar
Butta
Default Re: Where is the starter??? (Ramrod92)
Great thanks!!! :cheers:
Old Sep 27, 2003 | 08:00 AM
Mr Mojo's Avatar
Mr Mojo
Ransome, you need to clean the underside of your car! :D
Old Sep 27, 2003 | 10:32 AM
Ramrod92's Avatar
Ramrod92
Default Re: Where is the starter??? (Mr Mojo)
Frank, you're killing me. Actually, that's not mine. You cann't see the starter on mine. :thumbs:
Old Sep 27, 2003 | 11:15 AM
killain's Avatar
killain
Oldtimer
Are you refering to the starter, or the Opti-spark distributor ?
Old Sep 27, 2003 | 11:26 AM
Alchemist's Avatar
Alchemist
NC Events Coordinator
:thumbs:
Holy SCHMIDT!!! :eek: now THAT'S an OIL PAN!!!!! :eek:
To Where is the starter???
