Winter Storage
Old Sep 29, 2003 | 12:06 PM
csc67's Avatar
csc67
Default Winter Storage
Almost time to store the vette away for the winter - any suggestions
Old Sep 29, 2003 | 12:50 PM
DarkRed95's Avatar
DarkRed95
Default Re: Winter Storage (csc67)
I posted this before I hope this helps:
1. Keep in the garage (heated if you could).
2. Change oil and filter (Mobile 1).
3. Wash and clean car, detail including rubber, and wheel wells.
4. Check anti-freeze protection.
5. Clean garage where it's stored and put down plastic as a moisture barrier under the entire car including the tires.
6. Put on a good car cover on. (I use Max Tech), but whatever you like. Don't put anything on top of the car!
7. Disconnect the negative side of the battery. Charge up the battery. (I do this for my boat batteries I charge them half way through the winter again and then right before you start it!
8. Don't start the car until spring, it will be fine! I do not recommend running the engine because a warm engine creates water condensation when it cools down. But if you do start the car make sure it is at normal operating temperature before shutting it off.
9. I always put Stabil in to a full tank of gas run it to get through the fuel system. I do this for all my stored engines. Last up to 15 months.
10. Inflate tires to 5 lbs. over proper pressue.
11. I cover the exhaust pipes so nothing gets in there.
You can put in some moth ***** or Irish Spring or cedar for those little guys and some moisture protection bags in there.
I you remove the battery, put it on some wood. Don't put it on concrete!
**How about the insurance? Just need fire and theft? Why pay for more than what you need? Save yourself a bundle for next year!**
:thumbs:
Old Sep 29, 2003 | 01:27 PM
Lone Ranger's Avatar
Lone Ranger
Hey there's still a some more crisp, clear autumn days ahead. Good time of the year to go out and cruise a twisty backroad-- check out the fall colors of the leaves...
Old Sep 29, 2003 | 01:35 PM
QuikZilver's Avatar
QuikZilver
Default Re: Winter Storage (Lone Ranger)
Glad I don't live in the colder climates...I would hate to have to store my Vette for a couple of months.
Old Sep 29, 2003 | 04:41 PM
DarkRed95's Avatar
DarkRed95
Default Re: Winter Storage (Whitvette)
A couple of months maybe 5 months it really su.... Same thing with the hard water up here no boat either. They want to know how to fall in love with your Corvette again after that amount of time it's easy!
[Modified by DarkRed95, 4:11 PM 9/29/2003]
Old Sep 29, 2003 | 04:59 PM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default Re: Winter Storage (DarkRed95)
i always try and hold out until thanksgiving. as long as their is no snow, and more importantly salt, on the ground, the cold air is great for the car. It just seems like I posted this yesterday:
http://forums.corvetteforum.com/zerothread?id=511589
To Winter Storage
