Question about a brake squeak
Old Oct 12, 2003 | 01:45 AM
MaSTeRofDZaSTeR's Avatar
MaSTeRofDZaSTeR
From: "Drive like Hell, you'll get there faster." Tucson AZ
Default Question about a brake squeak
Just noticed today that my brakes are makin a little sqeak when I push down on em and only when I push down on em after I'm moving. It's a tiny squeak that's barely noticeable, but could it be the pads? Any suggestions? :confused:
Old Oct 12, 2003 | 08:28 AM
Midnite 88's Avatar
Midnite 88
Default Re: Question about a brake squeak (MaSTeRofDZaSTeR)
Don't know if it is true on your case but, brake dust can cause a slight squeak. Clean them with brake cleaner and see what happens.
Old Oct 12, 2003 | 09:18 AM
bac22's Avatar
bac22
Default Re: Question about a brake squeak (Midnite 88)
Is it consistent? How many miles on your pads? It is not unusual for pads to squeal, especially the semi-metallic pads.
Old Oct 12, 2003 | 10:37 AM
Texas CE's Avatar
Texas CE
Default Re: Question about a brake squeak (bac22)
Yep, :iagree:
You can clean the pads & rotors by backing up and braking several times.
Even my Hawks have little sqeakage I can hear when running around 30mph.
Now if they really sqeal loudly when braking that could be the brake indicator saying it's time for new pads.
Old Oct 12, 2003 | 10:28 PM
MaSTeRofDZaSTeR
Actually, it's kinda wierd. It was soft yesterday, but today it sounds louder. It's more like a loud whistle screech than anything rubbing against anything else. Sounds like screeching rubber tires but to a more whistle-like degree. Dunno how to better describe it. BTW I just had my rotors for the rear done aswell as a new power brake booster installed. Rotors were done within the last 2 months and I think the pads were replaced, but I gotta check my receipts. I know the sound the indicator makes for new pads.....that happened to me 2 months ago. It sounds like metal against metal and its consistent when you drive and not just when you hit the brakes. This is only when you hit the brakes and sounds totally different. My guess now is brake dust maybe in the cv boot or somethin? I dunno, but I'm gonna take it to the mechanic tomorrow morning first thing. Thanks all :thumbs:
Old Oct 12, 2003 | 10:31 PM
MaSTeRofDZaSTeR
Actually you know the sound a bus makes when it makes a stop(like a city bus)? That compressed whistling/whistle screech? That's EXACTLY it.
Old Oct 13, 2003 | 05:24 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Yup.. the rotors can get glazed or dirty and cause this. What happens, is the contamination on the rotors will cause the pads to vibrate, and the shoes (back of the pads) squeak against the caliper.
I'd try cleaning them off with brake cleaner, or even doing a few hard (but brief) stomps on the brake pedal.
They also sell some spray-on stuff "Disc Brake Quiet" that you put on the BACKSIDE of the pads/shoes like I mentioned to prevent the squeaking noise even if the rotors get glazed/dirty. :cheers:
[Modified by CentralCoaster, 2:25 AM 10/13/2003]
Old Oct 13, 2003 | 09:08 PM
MaSTeRofDZaSTeR
Yep you guys were right. Brake dust. My mechanic said it probably happened when it rained heavily here a week ago. The brake pads are big on c4s he said so it shouldn't be an uncommon thing..which it doesn't sound like it is. I tried backin up and braking a few times and it seemed to work a little by pushin out the crap, but he put some brake cleaner on it anyway and it hasn't squeaked since. Thanks all :thumbs: Learned somethin new.
Old Oct 13, 2003 | 09:10 PM
MaSTeRofDZaSTeR
Default Re: Question about a brake squeak (CentralCoaster)
Hmmm I'll look for that stuff next time I'm at the parts store...Disc Brake Quiet. :cheers:
To Question about a brake squeak
