L98 reliability
Old Oct 18, 2003 | 09:07 AM
DSKRALL's Avatar
DSKRALL
Default L98 reliability
There was a recent post about LT1 longevity, so now I am curious about the reliability of the L98s.
David
Old Oct 18, 2003 | 09:13 AM
mikestuff's Avatar
mikestuff
Default Re: L98 reliability (DSKRALL)
My 88 has 112K on it and counting. I have pretty well rebuilt the rest of the car, but have not had to touch engine internals. Still uses no oil. Don't know how others have done. :)
Old Oct 18, 2003 | 09:25 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
3 L98's here - one of them was at 145k when I removed it (Still pulled 13.0@109 - w/ some mods ;) ) Absolutely NO issues :flag
Old Oct 18, 2003 | 09:42 AM
Red Tornado's Avatar
Red Tornado
Default Re: L98 reliability (*89x2*)
Wow thats great to hear :thumbs: With an average of 6-7k miles I put on mine a year, I';ll be taking my baby to the grave with me :lol: :cheers:
Old Oct 18, 2003 | 09:52 AM
Storz's Avatar
Storz
Default Re: L98 reliability (bradvette)
My 87 has 135k on it and still runs like a champ, its even my daily driver, winter and all :eek: :thumbs:
Old Oct 18, 2003 | 01:29 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Good to hear, because a lot of the stuff up for sale where I'm looking is in the low 100k range.
:seeya
Old Oct 18, 2003 | 05:44 PM
1Patriot's Avatar
1Patriot
Put more than 125K on my 88 Z-51, 4+3 coupe and when I gave it to my son it was still in superb condition, engine and all.
Old Oct 18, 2003 | 06:00 PM
ElisTwoCents's Avatar
ElisTwoCents
St. Jude Donor '05 thru '24
Default Re: L98 reliability (1Patriot)
157k and running good. Had to rebuild the transmission at around 148k. She still hits the track about once every month or two and gets driven daily as long as the weather aint bad :U Has no oil issues as well :cheers:
Old Oct 18, 2003 | 07:11 PM
J Z06's Avatar
J Z06
I have to say, I am more than pleased with how reliable my L98 is even with the Lingenfelter 383. Nearly 46,000 miles on the engine and it has never let me down or left me stranded. Daily driven also.
:thumbs:
Old Oct 19, 2003 | 12:01 AM
87NassauBlue's Avatar
87NassauBlue
L98'S were a great design, very reliable.b
Old Oct 19, 2003 | 12:58 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My 86 has 110k. Uses no oil, runs solid. :thumbs:
Old Oct 19, 2003 | 01:50 AM
severe-1's Avatar
severe-1
An L98 is still a basic 350 chevy. The most popular and I beleive the longest production motor ever produced.
It is also the cheapest motor to build... As long as its not in a Corvette!
Old Oct 19, 2003 | 04:34 AM
RedRiderZR1's Avatar
RedRiderZR1
Default Re: L98 reliability (severe-1)
When I sold my 87 it had 180k on the clock. Still ran excellent and VERY little oil usage. Great durable engines.
Old Oct 19, 2003 | 12:24 PM
jsinga's Avatar
jsinga
Default Re: L98 reliability (RedRiderZR1)
215K on my 87 automatic Z-51. Engine, trans and rear still orginal. Engine puts out it's puff of smoke 1st thing in the morning. Doesn't use a 1/2 a quart of oil between changes. Water pump changed @90K miles.
Suspension will wear out long before the engine. I've replaced wheel bearings, u-joints and steering rack, oh, and brake rotors in the front.
JS
Old Oct 19, 2003 | 04:26 PM
BobLocke1950's Avatar
BobLocke1950
My 85 has 93K and puffs a little smoke at start up. I just got it this June, so I'm not quite sure of the cars history yet. Has 3:07 gears and is a 4+3 standard. It runs real strong, idles quiet, no engine noises. You can't kill those Chevy small block engines. :cheers:
Old Oct 19, 2003 | 05:31 PM
Mike263's Avatar
Mike263
Default Re: L98 reliability (JrRifleCoach)
116k on my 86 - ditto.
Old Oct 20, 2003 | 09:47 AM
corvettemaster's Avatar
corvettemaster
mine had a 113,000 and was runnin real good. didn't burn a drop of oil. but due to the cold air intake and water crossing the road, i hydro-locked it and had to rebuild it due to a bent rod and some serious knocking. hopefully it will last another couple hundred thousand before i'll have to worry about it again :smash:
To L98 reliability
Old Oct 20, 2003 | 10:08 AM
aj1988's Avatar
aj1988
127,000 +. Other things are starting to go, but the engine runs great and doesn't use oil. What more can you ask for?
Old Oct 20, 2003 | 10:58 AM
CREWZIN's Avatar
CREWZIN
Default Re: L98 reliability (aj1988)
:iagree: 137,000 here and no major engine work. :cool:
Old Oct 20, 2003 | 11:34 AM
torque91's Avatar
torque91
Keep the oil changed and the coolant in good shape and it should last over 200,000 miles with no problem.
I had to change head gaskets at around 130,000 miles because I had fan problems and let it get hot.
I did a complete rebuild at around 193,000 miles. It only needed head gaskets again but I decide to completely rebuild it while I was at it (I didn't maintain the coolant and it started to leave a build up on the head ports leaving very small holes for the coolant to pass). So basically, the only trouble I have had was because of mistakes I made. Life leason learned, I hope.
