Running too hot?
Old Oct 19, 2003 | 06:52 PM
jrc's Avatar
jrc
Cruising
Default Running too hot?
The dash display on my 89 tells me the engine temp starts out at about 150 degrees but then (depending on conditions) goes to 240+ is this to hot ?
Old Oct 19, 2003 | 07:44 PM
Strick's Avatar
Strick
Default Re: Running too hot? (jrc)
I know you're fairly new to the forum. This topic is covered in full in past discussions. Just look back at least a month or so, and you'll find all the answers and fixes. Yes, I think 240 is too hot, but not terminal. 200-220 is about normal.
Old Oct 19, 2003 | 07:49 PM
CanadaVette's Avatar
CanadaVette
Default Re: Running too hot? (Strick)
I run about 190
Old Oct 19, 2003 | 07:50 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
IMHO YES!!!!
On the open road, engine tmps shpu;d be less than 190...less than 180 if you subscribe to the cooler is better school of thought!
Several potential problems come to mind
1) your coolant sensor/ guage aren't working
2) You have a themo that is stuck partially open (or partially closed)
3) You have a lot of trash in front of the radiator(remove and clean)
4) You need to change to a 180 thermo
There are many other potential problem areas including blockage in the radiator, collapsed hoses, etc.
Give us a little more info and history on your car
:seeya
Old Oct 19, 2003 | 08:15 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
Default Re: Running too hot? (jackdaroofer)
IMHO YES!!!!
:iagree: And don't forget to check to see if both cooling fans are workin'. ;)
Old Oct 19, 2003 | 10:44 PM
1990CORVETTE's Avatar
1990CORVETTE
I run about 160-170 -------24 - 7 - 365.......... I purchased a manual fan switch..... :cheers:
To Running too hot?
