Painting pros inside
Do not pay them cash or check!
Good Luck
Forget about what you saw the other day, now when you go to pickup your car and pay for it, and the end result is less than expected, then you let them have it...... But trust me, a base coat/ clear paint job that hasn't been color sanded and polished looks like crap.
:cheers:
First of all, clearcoat is not put on in "coats". NEVER judge a paintjob when someone says, oh yeah, I've got 7 coats of clear... That's BULLpoopie.
Paint is put on in thicknesses, obviously, to produce a thickness of say 3mils you would end up getting roughly 2 coats of basecoat and 2 coats of clearcoat. Anything less will not leave the protection available that comes with using a BC/CC system and if you put too much more than that, the paint could crack, solvent pop or yellow.
The only time more clear is put on is when a paint job is for a show car.. even at that, a car must be blocked, primed, based, cleared, sanded down and rebased and cleared AGAIN. If it's not a showjob, then a painter may add extra clear if he has the intention of wetsanding and buffing. Wetsanding will remove some of the thickness and thus leave a final paintjob with the correct thickness.
One thing that never ceases to amaze me is when a shop tries to sell a customer a job by stating that they are putting on 6 or 7 coats of clear. Can anyone tell me if 12 light coats of clear is better than 3 heavy ones... it all is determined by how much a painter lays down on his swath of paint and spray pattern. If the quantity of paint that is being put down is correct, then generally it will come out to a couple coats of clear (again, for a "normal" paintjob)
As far as having orange peel in a paintjob, a good painter should be able to spray and leave a close to mirror like finish that needs minor wetsanding and buffing just to shine it up and/or remove minimal trash. (you can always tell how good a prep job prior to painting is by how much trash is in the paint before buffing)
I myself am only a mediocre painter, I have to wetsand and buff my jobs... however, my painters can paint circles around me and leave a finish that is second to none before it has been wetsanded and buffed.
Orange peel can be caused by several things. Incorrect ratio of reducers, wrong temp reducers, wrong temp spraying, incorrect spray patterns, too much air pressure, standing too far away from the vehicle, etc, etc...
I would wait until I saw the finished product and if you are not satisfied with the finish, tell the shop that you want the car wetsanded and buffed before you pick it up.
Hope that helps...
Mark
Agreed, maybe a street car has less coats but they still do the wet sanding unless its an excellent painter laying down the coats
[Modified by ld85, 10:28 PM 10/27/2003]
What you said is EXACTLY what I'm talking about. 34 coats??? Okay, let's look at this. 34 coats @1.5-2 mils per thickness, I'd say that you should have oh, I don't know, about 1/4" of clear... If the coats were ever so light, what's the point, are 34 coats better than 4 thicker coats? And most certainly, the coats had to be fairly light because even if you're wetsanding, you can only end up with a certain thickness... otherwise the doors won't open, emblems won't fit and things like lock cylinders won't go through the hole all the way.
Not to mention that too much clear will not allow the previous coats to breathe, the solvents will try to come through and the end result will be little tiny bubbles known as solvent popping.
It reminds me of when I watch inexperienced bodymen apply any bondo. They apply it, sand it down, apply it, sand it down, opps, a little more, sand it down... What a waste. It's the same thing with clearing. Too much on just to wetsand it off is a waste of time and materials.
THE BOTTOM LINE IS IT CAN ONLY BE A CERTAIN THICKNESS WHEN ITS DONE.
Obviously you're car came out well but I'll play that game, I can paint your car in 12 coats... ;)
Ravinwolf,
Car looks great (especially for doing it in a garage, muuuch harder than using a booth) I'd like to see pics of it once it was wetsanded. Looks like you layed the clear down pretty well. If all you used was 1500 to get some trash out, then it was definitely laid down well.
Typically, when I wetsand a car. Depending on how much clear was put on, I'll start off with 1000 grit, then 1500, 2000, 2500 and 3000 if necc.
No disrespect or insults to anyone, just saying like it is...
:cheers:
Mark
[Modified by C4 Newbie, 5:54 AM 10/28/2003]
I would say go there and ask if they are going to wet-sand/buff the car. If so give them enough time to get it done so that they don't do a rush job. If they say no might as well tell them it is not satisfactory before they go to long. Good luck.
:iagree:
When we painted my dad's 86, the clear (2 coats) turned out pretty damn good considering we had no booth. There is so little orange peel that we decided not to sand at all. Unfortunately, when you look close you can see dust etc. in the paint from no booth to keep things clean.
Paint is to thick, low air pressure, heavy coats, hot weather, etc.
A paint finish should be very close to a wet sand and buff finish before it is wet sanded and buffed.
A rough finish after a spray just goes to show you that the painter is clueless.
It makes the work of wet sanding and polish a lot harder to do.
A good spray job should mirror the prep work.
As far 5 coats, 10 coats, etc. I consider a coat of paint as a complete pass around the car with the spray gun. Thats one coat. 2 passes thats 2 coats.
If your paint is reduced properly and the temps are good each coat should melt into the previous coat and become one coat.
So in that sence its really only one coat.
The paint job in question may very well trun out good buts the hard way around the horn.
How do I know? I've been using the same spray gun since 1980.
